Author Topic: carb tuning  (Read 1608 times)
Offline hymodyne
carb tuning
« on: May 04, 2005, 07:45:29 PM »
evening,  on my 500/4 K1, I:
I re-built the carbs,
setting float height to 26 mm
replaced o-rings inside float bowl,
gas-air screw opened 1 turn +/- 1/4, acording to specs
engine starts, but runs rich, #1 carb blowing fuel. engine bogs down and dies as I open choke, comes back to life as I close the choke more and more.
hymodyne
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: carb tuning
« Reply #1 on: May 04, 2005, 10:04:28 PM »
Did you synch the carbs with a set of vacuum guages or mercury tubes?
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline hymodyne
Re: carb tuning
« Reply #2 on: May 05, 2005, 03:28:11 AM »
no. i'll look into it.
MetalHead550
Re: carb tuning
« Reply #3 on: May 05, 2005, 07:05:31 AM »
