Lately when starting my CB750K4 with the starter, the button when it was pressed wouldn't spin the starter. So I'd either pull in the clutch lever (because I thought the problem might be due to the clutch switch) try pressing the starter button again (usually it would start in a couple of tries) or I'd kick start her.
Tonight, I tried starting the bike using the starter, but when it started I couldn't stop the starter from spinning. I even turned the ignition off and it kept spinning. I had to take the ground off the battery to stop the starter. If I reattach the ground to the battery, the starter starts spinning the engine even if the ignition switch is off. Bad solenoid? Any help would be appreciated. Thanks
