Author Topic: How to clean gasket surface on this hard-to-reach area?  (Read 847 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: August 30, 2011, 12:38:32 PM »
'71 CB500
The cover was off when I started this rebuild. You can see that there's some gasket material still on there. That space is really narrow though. Any suggestions as to how to get it off?
Offline Rgconner
Re: How to clean gasket surface on this hard-to-reach area?
« Reply #1 on: August 30, 2011, 01:06:41 PM »
I use an exacto knife with a chisle tip for that kind of stuff.
1975 CB550K aka "Grease Monkey"
KingCustomCycles.com
« Reply #2 on: August 30, 2011, 01:08:49 PM »
Aircraft paint stripper will release the bond and it will pop right off without fear of mechanical abrasion associated with scrapers.
« Reply #3 on: August 30, 2011, 01:17:26 PM »
removing the clutch basket gives you a better angle at it aswell,de glaze the steels at the same time maybe.
Offline vozzy
« Reply #4 on: August 30, 2011, 02:17:00 PM »
I'm with Dave, might as well check/replace/repair clutch while you have the cover off
« Reply #5 on: August 30, 2011, 02:39:01 PM »
there should be two locating dowels for the cover and a steel washer that goes over the kick shaft and bears against the inside of the case.
