And here's a question for the pneumatisists of our group: What is the porper method of fuel line routing for these old bikes?
Here's why I am asking:
On my 76 750F (with Single petcock), I have installed two inline fule filters. I have the one line running down from the tank to the "T" fitting, through the hole on the carb plate (so that it doesn't interfere with the choke linkage) and from there, each line goes through a filter before going to the fuel inlets on the carbs. Everything is below the level of the bottom of the tank, but the filters (which are see-through) don't seem to fill up at all and gas is only trickling through them.
Right now I have the filters above the air intake, but where the fuel line goes through the hole in the carb plate, it is about mid line of the carbs so the fuel has to go down, then up, and then down again. Should I rout the fuel lines so that they are all down below the carbs, or should I just leave them as they are?
