Author Topic: Having a hard time finding idle jets.  (Read 1491 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: August 31, 2011, 05:44:29 AM »
I have been scouring the Internet for new pilot jets for my 76 750k and can't find them anywhere. I would like a #45, but would settle for a #42.5 for now. Anybody have and inside on where to get these things. Already checked siriusinc with no luck.
Re: Having a hard time finding idle jets.
« Reply #1 on: August 31, 2011, 05:47:12 AM »
Got a friend looking also so will be watching----
« Reply #2 on: August 31, 2011, 05:52:56 AM »
Did you try Sudco?
Offline Bo24
  • 1970 CL100, !975 CB 750
« Reply #3 on: August 31, 2011, 01:48:43 PM »
You can try www.JETSRUS.com
Offline Coyote13
« Reply #4 on: August 31, 2011, 01:51:06 PM »
Try siriusconinc?  They tend to have some hard to find items
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline nccb
  • 1974 CB750 Four
« Reply #5 on: August 31, 2011, 05:58:48 PM »
have you checked out cb750cafe.com?  IDK if these are the right size you said but he has an assortment if you look through his parts list.  Hope this might help.
Offline nccb
  • 1974 CB750 Four
« Reply #6 on: August 31, 2011, 06:02:25 PM »
nevermind i just see the 40s.  try emailing him, i heard he is good about answering, he might know where to get some
Offline robdrobd
  • Who? Me?
« Reply #7 on: August 31, 2011, 06:11:40 PM »
Jetsrus has them. Should I go 42's or 45's?
Offline robdrobd
  • Who? Me?
« Reply #8 on: August 31, 2011, 06:23:23 PM »
I am guessing the 45's is the way to go. I upped the mains from 105 to 120. I figure the idles can jump up two?
Offline ABikeNamedTrouble
« Reply #9 on: August 31, 2011, 06:58:03 PM »
Advice from my own headache-causing experience:  order lots of different sizes.  With jetsrus.com, you can return the unopened ones.  The thing is, you'll never know exactly what size you need until you experiment, as every bike is different.
- Adam
1980 CB650c Custom
Keihin PD mechanical carbs
Stock air box and 4-4 exhaust
http://forums.sohc4.net/index.php?topic=97504.0
Offline robdrobd
  • Who? Me?
« Reply #10 on: August 31, 2011, 07:01:20 PM »
Good point, I'll just get both sets
Offline Iron Spade Cycles
  • I can build anything!
« Reply #11 on: August 31, 2011, 08:40:13 PM »
General rule of thumb is primaries go up one size for every 3 sizes of mains. Its a pretty good rule that works most of the time. I agree, these things are getting much harder to find.
Later Travis
Ride it like you stole it! Cause wounds heal, Chicks dig scars and Pain never last forever!
Offline c(b)hris
« Reply #12 on: August 31, 2011, 09:42:14 PM »
i think i found mine from this guy
http://www.northcityvintagehonda.com/servlet/StoreFront
i just called the number on the site and told him what i needed.  he looked around and called me back.
75 CB550
74 CB750
Offline dtmmil
« Reply #13 on: September 01, 2011, 02:54:32 AM »
I have always heard that on those carbs a jump on the pilot is not necessary. The guys I heard it from run open pipes and open intakes, and run 120-125 jets without changing pilots.
Offline robdrobd
  • Who? Me?
« Reply #14 on: September 01, 2011, 12:32:12 PM »
If they are racing the bikes I could see no change because the bike runs well with any kind of throttle, but I need to do a mime or so of stop and go before I hit the open road and need a better lower rpm performance
Offline dtmmil
« Reply #15 on: September 01, 2011, 06:39:16 PM »
Have you tried adjusting the air screws to help, turn them in just a little with decrease air in, and richen up the pilot side.
Offline robdrobd
  • Who? Me?
« Reply #16 on: September 01, 2011, 06:50:12 PM »
Will a bike buck/skip if it's too rich? Air screws are nearly seated. I will back them out this weekend and keep going in a quarter turn until something changes. Hopefully for the better.
Offline dtmmil
« Reply #17 on: September 02, 2011, 08:28:14 AM »
"Tip: It would not hurt to carry a screwdriver with you and ride around roads where you would be stopping and cruising slowly, and as much as possible in 5th gear so you are spending as much riding time using the low end circuit. Pay attention to how the bike sounds as you slowly pull away from a stop. If it stutters a little or balks a bit back the screw out 1/8 turn and test again. If it pulls away fine but has a stubborn idle turn the screw in 1/8 turn and test again. You may have to just nudge the screw to find that sweet spot but in no time the bike will lope at idle yet pull away from a stop smoothly. A vacuum sync before hand is strongly recommended."
I borrowed this from an old dog! haha Maybe it will help
http://www.hondachopper.com/garage/carb_info/plug_chops/plug_chops.html
this is his also, maybe this will help too.
Offline grasscutter
  • Love the CB650.
« Reply #18 on: September 02, 2011, 06:45:28 PM »
+1.  Many folks think an increase in main jet automatically means an increase in idle jets, pilot jets.  Not true.  Mains are usually 1/4 throttle through WOT.  Fuel needs are not changed dramatically @ idle (unless you've done some major engine build, blue-printing, head work, etc.)
**Coming from an old vintage snowmobile racer:  If wanting to really dial in the 'off the line jump', it will take a nice smooth transition from pilot to main.  But wait, that all depends on what RPM you dump the clutch.  OK, Ok.. I'll stop.  To much information.
Come on!  We're burning daylight!
