Author Topic: Oil Lines to Oil Tank  (Read 980 times)
Offline WhyNot2
  • I'm finally an
« on: September 01, 2011, 07:08:54 AM »
Are the parts numbered 17 and 23 washers or gaskets and where do they go?
I'm thinking that both lines should have some sort of o-ring or something at the tank connection area.
Am I correct? I do have an oil leak at one of the lines, but it looks as if it is coming from under the mesh sheaving.
Appreciate the help.
Thanks.
Re: Oil Lines to Oil Tank
« Reply #1 on: September 01, 2011, 07:12:05 AM »
I think they are metal crush washers. 23 may be for the drain bolt ?
Offline WhyNot2
  • I'm finally an
« Reply #2 on: September 01, 2011, 07:15:48 AM »
But
Thanks ekpent,
There are three parts that look like they may be washers.  17, 23 and 22 which looks like it goes to the drain plug.
What do you think?
« Reply #3 on: September 01, 2011, 07:20:07 AM »
Yep, Eric's on the money, they're crush washers. 22 and 23 are for the oil lines, and 17 is for the drain plug. Cheers, Terry.  ;D
Offline WhyNot2
  • I'm finally an
« Reply #4 on: September 01, 2011, 07:51:55 AM »
So.............................................................my leak may well be, that one of those washers are missing.....
« Last Edit: September 01, 2011, 08:01:51 AM by budlite282 »
Offline DedHed
  • Boob
« Reply #5 on: September 01, 2011, 08:04:56 AM »
I've read here.. Never seen it myself.... That the lines themselves can "Weep"... May be the hoses....
Just a stab....
Now back to our regular programming....
Phil
CB750 K4
bollingball
« Reply #6 on: September 01, 2011, 10:28:42 AM »
+1 crush washers You can get them at most any auto parts place They don't need to be metric take a old one with you to size them up Lawn mower shops have them also. I get them there when I change my oil.
It could be the lines weeping. I woud try the washers first.
« Last Edit: September 01, 2011, 10:30:23 AM by bollingball »
Offline WhyNot2
  • I'm finally an
« Reply #7 on: September 01, 2011, 10:57:42 AM »
this is quite a leak, when the bike is running, its a constant drip.
Then stops when when i shut 'er down
Offline 78whiteorbs
« Reply #8 on: September 01, 2011, 01:16:23 PM »
Is it a nice drip on the right side of your swing arm that splatters your rim and tire?
If so I just noticed a similar leak on my new old bike. Did some research and have to take a closer look today but it appears that it may be the trans breather hose is cracked-
check this thread here- http://forums.sohc4.net/index.php?topic=53096.msg568363#msg568363
