Is the Esprit rust remover available locally ? and what's the Best way to remove all the varnish prior to using this new type of rust remover ? I want to completely remove any varnish that'll interfere w/ the de-rusting action of it.
+1 ^ if any one can answer this it would be great! I'll even throw in some non-exsistant brownie points
Do you need to use a product like Red Kote tank sealer afterwards? or after the process it is good to go with out the sealer?
Tony
Hi Tony,
No Espirt is not available locally, but is easy enough to order through www.rustremoverproducts.com. Lee is very helpful and has fast shipping.
As for varnish removal your plan of attack will depend on the quality of the paint on your tank. Carb cleaners like autozones value carb dissolve varnish instantly, but will remove paint as well. If your paint is very good avoid acetone or carb cleaner all together and use boiling hot water and some mild soap like dawn. You may try simple green, but I am not sure if that is paint safe or not.
Fill your tank with the boiling hot water and some dawn and let set for several hours to a full day. If you don't want to boil the water you will have to wait much longer for the varnish to dissolve.
After that dump out the tank give it a good rinse with clean water and add your E-Spirit solution. Try to follow directions on the bottle as it will help with rust removal. Heat turbo charges the derusting process of these products.
Most of the rust was gone in 12 hours with the rest gone the next day. The CB360 tank was an extreme example. Most tanks won't need so much prep. If there is only mild varnish you can just dump the ESpirt in. I like to remove as much junk first so I can reuse the Eprit and get the max life out of it. If this is not a concern you can probally just heat water add the Espirt and forget about it. I like to reuse the product. Good Luck!
Chewy! This is great info, thankyou! I know that both Bill and I have nice paint jobs on the tanks and dont want to mess them up, so the carb cleaner is out. I have heard of people using BB's with the hot water/soap solution so they wont dent the tabk with nuts and bolts.
But as for after the Esprit I read about the MMO, but do we have to use something like Red Kote after it? Or do we not have to worry about using a product like this at all to seal the inside after.
Thanks again!
Tony
Tony,
I'm glad someone was finally able to answer that..,this is all new to me also.
If it was me...,I'd prefer to keep the tank full w/ fuel as much as possible to keep it from rusting and give it a light coating of oil before putting it away for the winter(if you even plan on "putting it away"
;but just use the rust remover treatment and use the tank without lining it w/ Red Kote or similar sealing coat.
I've found that if the M/C sits in the direct sunshine regularly...and then cools off at night, well that is a large change in temperature that causes the tank to develop condensation inside(water)and that is one of the reasons tanks rust inside so much.I think when they sit open w/o fuel in them water vapor collects in there also.
When you park your bike, try to park it in the shade or in a cool spot w/ shade..or cover it from direct sun to avoid too much condensation at night when it gets cooler.
I imagine the best way to keep the inside of the tank from rusting is to fill'er up every day and keep it filled.I think when a tank is lined w/ a sealer it has a useable life(not sure how long..it depends on the prep. before you line the tank)span and after that the lining will start to lift a bit inside the tank and can clog your fuel system...,that's why I'll hold off on lining my tank w/ Red Kote this time around.I used to line them All the time w/ no short term negative effects that I knew of..again,it all depends on how well you prepare the interior of your tank;it HAS to be 100% dry for 100% adhesion..and that takes quite a while to do,most guys don't have the patience to wait almost a week before applying the coating...and then wait another week for it to cure up well enough before they pour fuel into it & begin to use it.
