Author Topic: 500T triple tree on a 550?  (Read 829 times)
Offline Wtrdog
« on: September 03, 2011, 02:28:21 PM »
i wanna run 1" bars on my '76 cb550.  Any issues with using a 500T triple tree top on my 550?  this way i can get 1" dogbones and run the 1" bars.  didn't know if there were any issues.  they are both 35mm but i don't know if there is any other reason it wouldn't work.
I saw the triple tree swap and it looks like the 550 has less offset, but I saw somewhere else that they all had 0 offset.  so not sure if it would work or not.
« Last Edit: September 03, 2011, 03:02:06 PM by Wtrdog »
Re: 500T triple tree on a 550?
« Reply #1 on: September 03, 2011, 06:22:37 PM »
The 500T has more offset (distance from steering axis to fork centers) than the 500/550 fours. Fork center to fork center width is the same.
Offline Wtrdog
« Reply #2 on: September 04, 2011, 06:41:31 AM »
ok cool so i can do a full swap and be good.
thanks i hoping to hear some good news.
Offline johnrdupree
« Reply #3 on: September 04, 2011, 08:27:11 AM »
I have a 500T triple tree on a 550K1 and haven't had any issues.  The steering stems appear to be the same; I used an All Balls tapered bearing kit and it dropped right in.  The mount for the brake junction is a little different but the junction block will bolt right on.  You'll lose the steering lock, if that matters, and the 500T top clamp has a mount for the ignition lock which you may or may not need.  I cut it off and smoothed it out since the stock ignition lock for the K1 is under the tank.  I don't know if the stock headlight ears will work because I omitted them and went with aluminum ears.  And the instrument mounts are different.
Good Luck,
~john
« Last Edit: September 04, 2011, 03:47:52 PM by johnrdupree »
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
« Reply #4 on: September 04, 2011, 01:43:08 PM »
Because of the different offset the steering geometry will be much different.
