Author Topic: Leaky fork tube... CB750K4  (Read 829 times)
Offline sbparks
    • My Hobby...
« on: September 05, 2011, 01:11:28 PM »
Guys,
 Rainy day here in upstate NY so I torn down my CB750K4 front end due to a leaky (right) fork.  Replaced the seals last summer when reassembling after a full rebuild.
 I found an ugly (large) pit in the slider chrome surface that no seal would be able to work with!  Not sure why I didn't replace originally!
 I posted in the classified, WTB Fork Tube: http://forums.sohc4.net/index.php?topic=95202.0  as I am sure I'll need a new tube.
 Will I need to replace the (new last summer) seal as well?
 Otherwise... Looking for a replacement slider tube for my CB750K4.
Thanks, Scott
Offline alfego
Re: Leaky fork tube... CB750K4
« Reply #1 on: September 05, 2011, 01:28:49 PM »
For as much work & time that goes into tearing down the forks, I have always used new fork seals and have never reused an old seal.  Don't recommend it, not worth it.
Alfego
Offline mrbreeze
  • Not your average
« Reply #2 on: September 05, 2011, 01:32:55 PM »
Alfego
+1. If you ran that seal over that pit in the fork.....I would think there was a good chance the seal got messed up. For as cheap as they are....I recommend changing it. I answered your want ad for forks....lemme know.
MEMBER # 257
Offline phil71
« Reply #3 on: September 05, 2011, 03:12:43 PM »
i've been very successful repairing those pits with JB weld. It's a pain in the ass, but it can be done. Gotta clean it really well, and remove the rust with a wire wheel, then build it up in stages, and sand it down. A new fork seal might have gotten torn up, but you'd see it pretty quick if it did. what really happens is that pit holds the fork oil when it's under the seal, then lets it out on the top side when it pops back up. YOu'd be amazed how much a little pit will brng back up with it over the course of a 10 minute ride. Of course, if you can find a new fork for the right price, so much the better!
