Author Topic: CB500T tank on 74 cb550 what petcock you running?  (Read 1711 times)
Offline 1974cb550k
« on: September 06, 2011, 05:37:03 AM »
Just wondering what you guys were running for petcocks on a cb500t tank when put on a cb550. I moved the half circle mounts back 1/4 in on the front of the tank to make room for the clip ons. It then put the petcock bung directly over the #1 carb. I ended up using a cb400f petcock with slight modifactions. The prob is that it has a single feed. It needs to be short and have a dual vertical feed.  Thanx
Offline stidds
Re: CB500T tank on 74 cb550 what petcock you running?
« Reply #1 on: September 11, 2011, 02:43:28 PM »
I have a cb500t tank on my cb550 and I use the standard twin outlet petcock, however what I did to clear the number 1 carb was to turn the petcock about 1/4 of a turn and it slotted in between the carb hardware.
Offline 1974cb550k
« Reply #2 on: September 11, 2011, 04:58:17 PM »
The stock petcock (550) was hitting on the top of the carb. When turned does it set down between carbs? We talkin stock cb 500t ot bc550 petcock? Got a pic? thanx
Offline stidds
« Reply #3 on: September 12, 2011, 12:47:04 AM »
Here you go, I remember I had to raise the rear of the tank about 1/4" also.
Here you can see the standard 500t petcock has been rotated slightly..
Here you can see how much I raised the rear of the tank...
Now the gas pipes snake up through the horizontal bars on the carbs to join the twin outlet, I am using a t-connector as I only need 1 inlet for my carbs.
« Last Edit: September 12, 2011, 12:49:12 AM by stidds »
Offline 1974cb550k
« Reply #4 on: September 12, 2011, 09:13:55 PM »
M running the older style carbs with the dual feed. I might have to look into it though. Thanx for the pics
