Author Topic: What is this part?  (Read 2165 times)
Offline sockles
What is this part?
« on: September 06, 2011, 12:20:01 PM »
I have a Go kart with the cb 550 engine in it. I was wondering what this part is/does. Cause it leaks a LOT of oil while running. Is there a gasket that goes there that could be shot?
Swoop
Re: What is this part?
« Reply #1 on: September 06, 2011, 12:28:06 PM »
Looks like an oil pump to me
Offline Deltarider
« Reply #2 on: September 06, 2011, 12:29:13 PM »
It's the oil pump. O-rings deteriorate over time. I had to renew mine once when on a holiday in Spain. O-rings are still available.
CB500K2-ED Excel black
Offline WarwickE36
« Reply #3 on: September 06, 2011, 12:29:52 PM »
That is the pump, with the oil pressure sensor sitting on top, 3 orings seal the pump.  If the sensor is leaking a new one is required. or if you dont use the lights, plug it with a pipe threaded bolt.
also it looks like your starter could use another bolt
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline CycleRanger
  • No comment about being an
« Reply #4 on: September 06, 2011, 01:00:08 PM »
Howdy!
I'll bet that hauls ass!
You need to download the 550 shop manual from here: http://www.honda4fun.com/man_officina/man_officina.html
Within you will find the knowledge you seek!   :D
Offline xsmooth69x
« Reply #5 on: September 06, 2011, 01:37:16 PM »
put some pod filters or something over those carbs
1975 CB550 (FINISHED?!?!?)
Offline sockles
« Reply #6 on: September 06, 2011, 02:04:26 PM »
Thanks guys, now I gotta get the screws loose.
I had some pod filters on, but they keep flying off. new ones are on the way
Oh, it hauls alright! I'll try and get another video of a flyby if you want. Unfortunately I can't ride it much anymore since its home from my shop for the summer. Its so loud, I need to find something to dampen it.
In youtube:
/watch?v=w57MYmFL1jk
« Last Edit: September 06, 2011, 02:06:17 PM by sockles »
« Reply #7 on: September 06, 2011, 02:13:50 PM »
missing a starter motor bolt.
Offline Rgconner
« Reply #8 on: September 06, 2011, 02:34:14 PM »
Replace the 3 Phillip screws with allens, you will get more consistent torque and less leaks.
Easier to remove and they look better too. Worth replacing any + screw with an allenhead to be honest. The original screws mauleasilyand often require an impact wrench to remove.
1975 CB550K aka "Grease Monkey"
Offline johnrdupree
« Reply #9 on: September 06, 2011, 03:10:28 PM »
Also, it looks like the mount that has a bolt is cracked.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
« Reply #10 on: September 06, 2011, 03:40:18 PM »
Howdy. Neat machine,does not thing have a shifter of some sort on it,if so must be some interesting linkage,or do you just run it in one certain gear?
Offline sockles
« Reply #11 on: September 06, 2011, 05:08:27 PM »
~john
Yes it is cracked, I'm waiting for this engine to crap out on me. It's been used so much especially from the previous owner.
Yes, there is a shifter on the right side of the steering wheel, that rocks forward and back, forward being 1st, back being the rest of the gears. I'll get a picture in a little bit.
How fast do these 550 bikes get up to? Heres my GPS timeslip.
(This Verification is really killing me)
Offline cameron
« Reply #12 on: September 06, 2011, 05:41:54 PM »
http://www.stainlesscycle.com/catalog/product_info.php?cPath=46_47_49&products_id=463
1976 CB550F
Offline 23tbucket
« Reply #13 on: September 06, 2011, 06:25:57 PM »
  Sockles: Dam cool. Those little four cylinders are just the right size for these kind of projects. I did something similar a few years ago....................
3/4 scaled down from a real one.....Couldn't afford to to the real thing!!
  Warwick: Just a side note.... That oil pressure sending unit fitting is not 1/8" NPT. It is 1/8" BSP. All Japanese motorcycles and cars have used the BSP pipe fitting system forever. You can cross-thread a 1/8" NPT fitting in there and it probably won't leak....but it's not right. You probably knew this...but for others take note.
http://pipeandhose.com/node/2
It's a looong story as to why the Japanese went with the British threading for pipe and not made their own metric stuff....goes way back to the big industrial revolution. As far as I can tell only the USA and Canada use the Imperial pipe threads?
« Reply #14 on: September 06, 2011, 08:42:04 PM »
65 mph in that thing must be a wild ride!  Stock 550 bikes will do over 100...
Offline Danold
  • Danold
« Reply #15 on: September 03, 2012, 10:38:35 PM »
How do you get that oil pressure sending unit off? I have a CB750 with the same gizmo only it is in a corner where you can't get your fingers around it.
Thank you
Jesus says lay up for yourselves treasures in heaven. Is that what D.B.Cooper was doing when he jumped out of that airplane with all of that money?
« Reply #16 on: September 03, 2012, 11:13:05 PM »
Unscrew it
