Author Topic: 1975 CL360: valve guide seals stuck?  (Read 897 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: September 08, 2011, 08:42:34 PM »
I have read that the valve guide seals are a good thing to replace when freshening up the top end.  I had to replace rings, so I am cleaning and lapping the valves.
  I got the valves off with a spring compressor, but don't seem to be able to get these seals off with the pressure/effort I gave it.  I didn't want to break anything, so I left them alone until I asked...
Also, the replacements from aftermarket gasket kits are notorious for being the wrong size, and the ones in the vesrah kit I got seem at first glance to be incorrect sized.  Should I just leave the current ones on there?
Thanks
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Offline chickenman_26
    • Motorcycle Consumer News
Re: 1975 CL360: valve guide seals stuck?
« Reply #1 on: September 10, 2011, 10:39:50 AM »
The groove in the top of the valve guides is really deep. The seals pop into the groove and hold tight. Lever it off from the bottom with a flat blade screwdriver. I haven't seen the Vesrah kit for that bike, but the guide seals in the kit I used for my 500/4 were fine. If you'd rather use genuine Honda seals, David Silver has them for sure, and maybe CMSNL too. Google the part #. 12210-362-005
Stu
MCN DTF
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: September 10, 2011, 12:16:06 PM »
Thanks stu. They definitely looked smaller in the kit - but I didn't take them out and compare closely.
I'll see if I can dig up some OEM to be safe.
Appreciate the help And part number.
Scott
~Sophocles
