Author Topic: piston cleaning  (Read 9020 times)
Offline illrational
piston cleaning
« on: September 12, 2011, 05:24:58 PM »
What's the best way to so it?can I soak it in carb cleaner and what's the specs on the pistons.I measured two at 58.5 mm rAch
« Last Edit: September 12, 2011, 05:27:48 PM by illrational »
Offline underachiever
  • Squandering my potential since 1989
  • 77 CB550K
Re: piston cleaning
« Reply #1 on: September 12, 2011, 05:47:29 PM »
If I remember correctly, acetone did a fine job on mine. Probably with carb cleaner as well. I believe some people have good luck with an acetone/atf? mix (maybe??) for unsticking seized motors which have sat for a while (as opposed to seized motors which have self destructed during use).
Stock 550 pistons 58.5mm x50.6 stroke at Pi x r2 x h x 4 = 544cc
Offline WarwickE36
Re: piston cleaning
« Reply #2 on: September 12, 2011, 05:51:07 PM »
People will chime in about flash rust and corrosion etc, but a solution of lots of DAWN dish detergent and water is what we were taught at school for cleaning pistons.  Soak it overnight at least.  As soon as it comes out of the soapy water brush it clean with a plastic bristle brush, and blow it dry with shop air or a hair dryer.  Then mist it with oil or wipe it down with oil and put it in a plastic bag until assembly.  It works awesome.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Re: piston cleaning
« Reply #3 on: September 12, 2011, 06:03:08 PM »
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
Re: piston cleaning
« Reply #4 on: September 12, 2011, 06:23:44 PM »
The best way I have found is an Ultrasonic cleaner using water and simple green. Also works wonders on Carbs as well.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
Re: piston cleaning
« Reply #5 on: September 12, 2011, 06:44:09 PM »
I couldn't agree more about Simple Green and ultrasonic cleaning. Worked amazingly well on my carbs, and relatively fast.
Offline illrational
Re: piston cleaning
« Reply #6 on: September 12, 2011, 07:25:25 PM »
what kind of ultrasonic cleaner..would love to be able to throw my head in the cleaner
Offline illrational
Re: piston cleaning
« Reply #7 on: September 12, 2011, 07:35:01 PM »
ok i feel stupid because i looked for a soda balster bottle at harbor freight...thansk MCRider but how did you get them so clean?
Offline luap
  • LAWL
Re: piston cleaning
« Reply #8 on: September 12, 2011, 09:46:29 PM »
if you dont have a ultra sonic cleaner I do half water half simple green an put themon a camping stove. soon as you get them hot the old build up falls off
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline CoachDoc
Re: piston cleaning
« Reply #9 on: September 12, 2011, 10:08:47 PM »
I'm a veterinarian, so I just "borrow" the ultrasonic cleaner we use on surgical instruments. Helps to be your own boss. It's compact, so  I had to do 2 carbs at a time with the carb rack on end, and then turn it over to do the other 2, but it worked super well with the Simple Green. Obviously smaller parts are no problem.
 Harbor Freight does sell them for far less than you'd pay to have the carbs cleaned by someone else. Check them out.
Re: piston cleaning
« Reply #10 on: September 12, 2011, 10:49:29 PM »
Well the soda blaster, along with a compressor, sprays...soda (25lb bag at harbor Freight, like gritty baking soda) which is benign, eco frindly, and the blast will remove anything on a piston down to the aluminum. Do it in the driveway (no neighbors, it does make a cloud). Rinse with water, clean air spray.
Re: piston cleaning
« Reply #11 on: September 13, 2011, 02:00:07 AM »
dont forget to run a tiny drill bit through the oil holes within the oil ring groove,,these will be full of crud and need more than just air blown through them.
Offline illrational
Re: piston cleaning
« Reply #12 on: September 13, 2011, 05:14:48 AM »
I appreciate your help fellas
Offline Trevor from Warragul
Re: piston cleaning
« Reply #13 on: September 14, 2011, 12:52:39 AM »
I put pistons in a glass jar & fill with paint stripper.  Leave for a day or two & the carbon just comes straight off!
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Re: piston cleaning
« Reply #14 on: September 14, 2011, 01:24:48 AM »
youll get away with it,but stripper will alter any precision surface in alloy,like the gudeon(wrist)pin area and the piston skirt surface itself,try and dip just the sooty crowns in anything as savage as stripper,read the instructions,,most say not for use on aluminium,,itll clean them alright though!use a jewelers screw driver and clean the ring grooves without gouging them,i use a little sand blaster for the crown and underside,get all them oil holes clean!
clean the skirts with worn out wet and dry.
Offline m in sc
Re: piston cleaning
« Reply #15 on: September 14, 2011, 06:28:34 AM »
for the 2-strokes i use lacquer thinner. peels the carbon right off. and they get way nastier than any 4-stroke piston normally does.
Offline illrational
Re: piston cleaning
« Reply #16 on: September 14, 2011, 07:00:28 AM »
I was worries about using something that would compromise the pistons
Re: piston cleaning
« Reply #17 on: September 14, 2011, 07:06:54 AM »
That's why i like the soda. totally benign.
Offline illrational
Re: piston cleaning
« Reply #18 on: September 14, 2011, 08:36:23 AM »
The ultrasonic cleaner and the sand with blaster is about same price at harbor freight so I'm going to go ultrasonic
Re: piston cleaning
« Reply #19 on: September 14, 2011, 08:50:32 AM »
Soda, not sand,  ;)  but you need a compressor with the blaster as well. So the ultrasonic sounds interesting.
Offline illrational
Re: piston cleaning
« Reply #20 on: September 14, 2011, 08:57:07 AM »
All the ultrasonic results I've seen have been exceptional
Offline m in sc
Re: piston cleaning
« Reply #21 on: September 14, 2011, 09:35:50 AM »
trferring to laquer thinner?? no, wont compromise it. anything too acidic or basic can possibly damage it, thats it.
also the chem dip carb cleaner works fantastic. On really nasty crap i also have an l&r medical ultrasonic i clean stuff in, and use 2/3 carb dip, 1/3 wd/40. great for carbs also.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
Re: piston cleaning
« Reply #22 on: September 14, 2011, 09:43:14 AM »
I've cleaned aluminum parts with spray on Oven Cleaner before. Takes the crap right off of it.
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline illrational
Re: piston cleaning
« Reply #23 on: September 14, 2011, 10:22:51 AM »
I have the chemically dip carbon cleaner but thought that might be too hard on it..;.man forget spending a extra 30 dollars if I can just use that
Offline m in sc
Re: piston cleaning
« Reply #24 on: September 15, 2011, 05:52:21 AM »
yeah, you can use that, its fine. the pistons aren't paper mach'e  ;D
shoot, a few mos ago i was milling holes in pistons for another project...  ;D
