Author Topic: Help..1977 cb550k valve removal  (Read 1055 times)
Offline illrational
« on: September 17, 2011, 05:10:45 PM »
I have tried three different tools to remove valves and have had no luck...suggestion please!!!!!!!!!!!!!!!
Re: Help..1977 cb550k valve removal
« Reply #1 on: September 17, 2011, 06:44:53 PM »
What do you mean "remove" . The spring compressor will not compress the spring enough to get the keepers out OR the valve will not slip through the guide?
Offline illrational
« Reply #2 on: September 17, 2011, 06:58:25 PM »
i cant get tool lined up to compress sprong...i put tool number in google and i have a couple of leads now
« Reply #3 on: September 17, 2011, 08:51:28 PM »
with a lump of rag stuffed in the combustion chamber lay the head on the bench the right way up,this rag will stop the valve from moving,place a socket that will clear the valve stem but still locate on the retainer,strike it with a hammer and the collets will release,have some rag wrapped around the spring to catch the flying collets(keepers),now you only have to get them back together.
Offline Danno
« Reply #4 on: September 17, 2011, 10:37:25 PM »
you can also use 1/4 inch rope in the bore of the cylinder or an air tool to hold the valve up while you compress the spring to remove the keepers
« Reply #5 on: September 17, 2011, 11:49:05 PM »
im guessing he has the head off danno,
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #6 on: September 18, 2011, 07:50:28 AM »
That's the #1 question here, it the head on or is it off?  Makes a big difference when it comes to tool options.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline illrational
« Reply #7 on: September 18, 2011, 10:48:31 AM »
its off
« Reply #8 on: September 18, 2011, 10:52:06 AM »
Large C-clamp with a socket over the retainer.  The socket needs a window or slot  cut into it so you can work the keepers with tweezers.
Sure.
Is it hard?
Offline illrational
« Reply #9 on: September 18, 2011, 10:54:47 AM »
while i also have everyones attention.....how can you tell if you have a bad carb....one of the carbs that i took off had rust in the holes and when i put carb cleaner and blew it out its the only one that when i blew air through it there seemed to be a obstruction but i dont kow what to do...do i just replace the carb,,,,,number one by the way
Offline illrational
« Reply #10 on: September 18, 2011, 10:56:33 AM »
i think ill go with the large cclamp with modified socket cheaper than buying the tool from whitney
« Reply #11 on: September 18, 2011, 11:38:16 AM »
For ur carb, you could peel a single strand of copper from a stranded electrical wire to see if you can dislodge the obstruction.  A guitar string works well also.  Just be careful that you don't change the diameter of the hole.  Use small wires made of soft metal.
Sure.
Is it hard?
Offline illrational
« Reply #12 on: September 18, 2011, 11:44:27 AM »
Thanks
