Author Topic: How to replace wheel dampners?  (Read 453 times)
Offline cloudsurfer
« on: September 13, 2011, 08:06:08 AM »
Finally got new bearing installed.  I put in brand new wheel dampners, but can't get the piece that holds the sprocket back in as the new dampners are tight.  Any trick to getting this back together?
KingCustomCycles.com
Re: How to replace wheel dampners?
« Reply #1 on: September 13, 2011, 08:18:15 AM »
Soapy water will slick them up and then dry out for proper friction. Push and pry other than that.
« Reply #2 on: September 13, 2011, 08:19:52 AM »
I slick them up with some armorall. I'm sure some would rail at that. Armorall is suspected of having bad stuff in it.
But some form of lube seems appropriate. Maybe just the tiniest bit of motor oil, vaseline, etc. And a rubber mallet.
Tire lube should be benign. Kings soapy water should work.
Offline cloudsurfer
« Reply #3 on: September 13, 2011, 08:20:21 AM »
ok, I will give the soapy water a try.  Thanks!  stay tuned......:)
Offline ofreen
« Reply #4 on: September 13, 2011, 10:55:06 AM »
Yet another good use for Ru-Glide.
Greg
'75 CB750F
