Author Topic: 750F(-1 fork tubes) Progressive Spring Install, Spacer Issue  (Read 801 times)
Offline Mandic
« on: September 19, 2011, 10:47:33 AM »
While assembling my rebuilt fork assembly I am running into an issue.  The fork setup is a 77 750F with "stock length" fork tubes.  They are brand new -1 tubes from Cycle-X but for a 77/78 750F this is stock length tubes(I compared them to the original tubes and measurements from here).  Now the Progressive springs come with PVC spacers about 1 1/4" in length.  The little note that comes with them says these spacers should be used in a 77 750F application.  However I just cannot get the tube cap nut to start threading.  There is just so much pre-load as I try and squish the o-ring into place and turn the nut, it just doesn't happen.  I took the spacer out and tried it again, with success.  It was still mildly difficult though.
 So my question is, has anyone run into this?  I'm figuring I can assemble without the spacers, ride the bike and decide if I need more pre-load then.  Mostly looking for experience from someone who has run -1 tubes or a stock 750F setup.
77 CB750F - Cafe/Daily Rider
Offline KRONUS0100
  • MAD MATT THE MANIAC
Re: 750F(-1 fork tubes) Progressive Spring Install, Spacer Issue
« Reply #1 on: September 19, 2011, 04:28:51 PM »
put floor jack with block of wood under motor to unload front suspension.
MATT
KingCustomCycles.com
« Reply #2 on: September 19, 2011, 04:42:30 PM »
I have found a socket and ratchet are the only way to push hard enough, and turn at the same time.  That is, after unloading the forks as stated above.
Offline Mekagojira
« Reply #3 on: September 19, 2011, 09:02:30 PM »
I had a bunch of problems - ended up using ratchet straps to pull down the socket extender I placed on top of the caps.  Definitely an ordeal.  Totally ghetto - but it worked. Be careful.
The progressive springs eventually eased up - the one that came in my bike ( no idea if they were stock… did not)
1975 CB750F
Offline Mandic
« Reply #4 on: September 20, 2011, 09:28:22 AM »
I ended up cutting 2 piece of 1" DOM tubing at 1/2" lengths and putting those in place.  The problem is I installed a set of Coffin Customs, Flat top fork nuts.  So there is no hex to turn with a socket/wrench.  Just one hole I stuck a punch in and turned.  Clean look but difficult on the install process.  Hopefully the 1/2" is enough.  If they get softer overtime or are too soft I will ride for a bit to break in the springs and try again with longer pieces.
The tubes were off the bike, so no loading issue.
And after I assembled most of the parts on the front end last night.
