Author Topic: '76 CB750 clicking noise coming from baffle?  (Read 3514 times)
Offline dylboss
« on: September 19, 2011, 04:52:46 PM »
So I've had this 750 for a week now after looking almost all summer for what I wanted.  Great overall shape.  I'm new to the stock 4-4 exhaust though on these CBs.  Got my '78 550 with a MAC 4-1.  I'm getting some sort of strange clicking noise at the baffle of the top left muffler.  I can't figure out what is causing this.  Has anyone else experienced this?
Current
- 1972 CB750 K2 - Brier Brown Metallic
- 1973 CB750 K3 - Flake Sunrise Orange
- 1974 CB750 K4 - Flake Sunrise Orange
- 1976 CB750 K6 - Candy Antares Red
Previous
- 1978 Honda CB550K
- 1972 Honda CL350 Scrambler
- 1972 Honda CB450
- 1998 Suzuki TL1000R
- 1993 Yamaha FZR 600
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: '76 CB750 clicking noise coming from baffle?
« Reply #1 on: September 19, 2011, 11:47:06 PM »
Not me,...but the 4-4 on the 76 750 would normally have HM341 mufflers (stamped on the top). These would have 2 or 3 (can't remember) internal baffles through the chamber and don't have a baffle fitted in the tailpipe. They have a small "diffuser" or end-cap. Is the noise from that end-cap? Pull it out and see if noise goes away to help diagnosis. I'd just guess that a "click" may be a metal component going through some "time of life" changes. e.g. rust,...or maybe it's loose!
Regards
Mark
« Reply #2 on: September 20, 2011, 06:18:09 AM »
Like Nancy said most of the baffling on the HM341 is done with seperate internal chambers and the 'baffle' at the end of the pipe is basically a cap-keep out a mouse etc. Take the cap off and maybe with a good rev a trapped chunch may fly out.Next step would be to remove the offending pipe and shake the hell out of it if it has a rattle and see if anything comes out.Heavy stream of water from a hose may help out some also.
Offline dylboss
« Reply #3 on: September 20, 2011, 09:14:51 AM »
Ok, thanks for the thoughts.  It does have the spiral ring type insert that I've already tightened down.  I'll remove it and see what happens.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
« Reply #4 on: September 20, 2011, 09:21:38 AM »
This is what the diffuser should look like on your HM341 pipe. As noted not a baffle per say. Eric   http://cgi.ebay.com/ebaymotors/Honda-NOS-CB750-Exhaust-Baffles-Diffuser-CB-750-Baffle-/320742293320?pt=Motorcycles_Parts_Accessories&hash=item4aadbaff48
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: September 20, 2011, 09:23:42 AM »
A hole in the baffle or the muffler can cause a "clicking" noise by letting out unmuffled exhaust pulses.  Does this click coincide with the exhaust stroke?
Offline dylboss
« Reply #6 on: September 20, 2011, 10:26:47 AM »
Yes, that's it!
Yes, it does seem to coincide with the exhaust stroke.  There are no visible holes in the exhaust itself.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
« Reply #7 on: September 20, 2011, 10:29:17 AM »
I am pretty sure but will ask anyway,you do have the two rubber pieces that mount the top and bottom pipes together all all is sealed well?
Offline dylboss
« Reply #8 on: September 20, 2011, 05:08:05 PM »
Yes.
The sound is coming from the tip of the exhaust.  I pulled the diffuser today and the clicking was gone.  However, I did look at the diffuser thoroughly, and I don't see any holes at all.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
