Author Topic: jake brake, jacob brake?  (Read 5077 times)
orange550
Re: jake brake, jacob brake?
« Reply #25 on: September 22, 2011, 06:24:06 PM »
The guy in the bar was correct. Many old flat trackers had an "engine brake". Especially the Jawas. As some else mentioned, it was a second spark plug hole. It had a spring loaded valve attached to a a tiny lever that hung under the clutch lever. The rider would pull the lever to instantly dump all the engine compression and then Pitch the bike into the corner. It sounds very similar to a semi Jake brake.  It's the coolest thing to hear and see. Takes me back and I'm not that old.
« Reply #26 on: September 22, 2011, 07:45:56 PM »
Yeah, those old flat trackers did not have much in the way of brakes. Used to have good flat track here in Kazoo many years ago,miss it.
Offline domer
« Reply #27 on: September 22, 2011, 10:46:37 PM »
Ive got one of those little suckers on my 70 Yamaha AT-1. Too bad i pulled the bike apart for a "cleaning" when i got it 18 months ago.   ::)
