Author Topic: now my number 4 carb is dumping gas out overflow...  (Read 1098 times)
Offline keaton_taylor
    • My web portal
« on: September 24, 2011, 08:13:00 AM »
like it was it's job... which I guess it kind of is.
anyway I went out to start the bike and charge up the battery (wife rushed me and I left the keys in ignition) and let her run for  bit and the number 4 carb overflow created a basketball sized (around) gasoline puddle. Could this be from a plug not firing properly or a bad float perhaps?
Insert silly conservative political message here.
1978 Honda CB750K
Offline Lostboy Steve
Re: now my number 4 carb is dumping gas out overflow...
« Reply #1 on: September 24, 2011, 08:25:17 AM »
Most likely your float or float valve is stuck.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline VTCBike750
« Reply #2 on: September 24, 2011, 08:31:29 AM »
+1
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline Rgconner
« Reply #3 on: September 24, 2011, 10:54:09 AM »
Until you fix it: Tap it with a stick or tool that has rubber coating to unstick it. I use the rubberized handle of the crescent wrench I keep in the saddlebags.
I have one that will stick if I do the freeway for a while and then pull into a stop and set the bike on the kickstand. Number 4 will stick 1 out of 5 times. A quick tap will set it free.
To fix it:
Remove the float, check in a glass of water for 30 min to see if it sinks from taking on water. Replace.
Check the float for height and the little backstop tab that determines how deep it will go. If that is bent, it will let the float valve lower enough to bind up and not go back up.
If it keeps doing that, time to replace the float valve. Find the kind with the little rubber tips, they seal better than the all brass ones.
1975 CB550K aka "Grease Monkey"
Offline grasscutter
  • Love the CB650.
« Reply #4 on: September 24, 2011, 11:49:03 AM »
To fix it:
+1
(with hand in the air)... I'll second that '+1'.
Come on!  We're burning daylight!
Offline cameron
« Reply #5 on: September 24, 2011, 12:23:40 PM »
could be a broken post!
Sine it is the number 4, it should be pretty trivial to remove the bowl and check it out,,,,
1976 CB550F
    • My web portal
« Reply #6 on: September 24, 2011, 06:56:10 PM »
I'm a total and complete noob when it comes to all of this so I'll check out my clymers and see how that works haha. any related material to check out?
1978 Honda CB750K
Offline lucky
« Reply #7 on: September 24, 2011, 07:36:37 PM »
Needs four new float needles. Thats all.
The rubber tips get hardened or degraded.
You JUST need the float needle, not the float needle and seat.
I just saved you a couple hundred.
Offline Flying J
« Reply #8 on: September 24, 2011, 08:01:29 PM »
Ill save you even more money. Is your tank a little rusty? if this leak becomes persistent you may want to run a in line filter for a little while .
    • My web portal
« Reply #9 on: September 24, 2011, 08:19:39 PM »
No rust in the tank. It was resealed several years ago.  I'll look into those float needles. Thanks guys!
1978 Honda CB750K
