Author Topic: Real Quick Question. CB750 motor Removal  (Read 1127 times)
Offline Humble Pie
  • Seeley #519
« on: September 26, 2011, 01:07:11 PM »
Will it come out of the frame without removing filter up front ?
Offline mcpuffett
Re: Real Quick Question. CB750 motor Removal
« Reply #1 on: September 26, 2011, 01:22:55 PM »
possibly with some jiggling  ;), cheers Mick.
KingCustomCycles.com
« Reply #2 on: September 26, 2011, 01:23:58 PM »
I never have been able to do it.  I do about 5 a year, did one yesterday.
« Reply #3 on: September 26, 2011, 01:27:14 PM »
I don't see how. And why would you?
« Reply #4 on: September 26, 2011, 01:42:12 PM »
I thought so. There are several threads here about the same problem. Misery loves company.  :(
Offline ksbrenn
« Reply #5 on: September 26, 2011, 01:50:39 PM »
A basic pipe wrench will get a good grip, but watch out for collateral damage.  Time to start researching other methods and pick the one that seems most likely to work for you.  It has to come off eventually.
Offline Dyrden
« Reply #6 on: September 26, 2011, 02:00:33 PM »
Slightly off topic, but I read about grinding down a flange on the right lower motor mount to ease install and removal.  Does anyone know if I grind the flange on the motor itself or on the frame itself?  Upon inspection both have a flange.
« Reply #7 on: September 26, 2011, 02:28:42 PM »
The tip is to flatten the top of the lug/flange on the frame. Leave the engine alone. Though i don't see why a little off the engine would hurt.
« Reply #8 on: September 26, 2011, 03:49:06 PM »
Offline kerryb
  • Not a very
« Reply #9 on: September 26, 2011, 04:51:04 PM »
yes, please share....with pics.  Do you need to replace anything besides the bolt?
Offline Dyrden
« Reply #10 on: September 26, 2011, 06:08:44 PM »
Thank you!
