Author Topic: Why does it run better when cooler temps?  (Read 4715 times)
Offline Duanob
  • Bold Timer
  • Gotcha!
« on: September 29, 2011, 12:21:38 PM »
I've always been curious about why carburated engines run better when it's cooler out then when warm or hot?
I've been riding to work lately and i the morning it's been in the 40's. My 550 has never run better! But in the evening when it's around 70+ it doesn't seem to run as smooth. Of course most people wouldn't notice the difference but since it's my bike I notice it right away. It's not that it runs bad when warm but just not as smooth as in the morning jaunt to work. I've always noticed this about every vehicle I've owned with a carb. Any explanation?
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Why does it run better when cooler temps?
« Reply #1 on: September 29, 2011, 12:33:04 PM »
Air is more dense when the ambient temperature is cooler as opposed to hot- you get more air in the engine per combustion cycle which means your carbs are tuned a little on the rich side.
« Reply #2 on: September 29, 2011, 12:51:29 PM »
What Dukie says,  that's why cars often have air intake all the way front - to get coldest air possible.
« Reply #3 on: September 29, 2011, 01:43:37 PM »
Cooler air is more dense, meaning each gulp of air contains more oxygen.
Offline vames
« Reply #4 on: September 29, 2011, 01:47:00 PM »
It's even more prounounced for some reason with two strokes. Many years ago I had a vespa that seemed to gain 5 hp when the temp dropped toward freezing.
Offline CycleRanger
  • No comment about being an
« Reply #5 on: September 29, 2011, 01:48:30 PM »
You get more spark too since the colder wires conduct with less resistance.....
« Reply #6 on: September 29, 2011, 01:57:25 PM »
Perhaps in theory.  Measurably, not so much.
It's the spark gap that determines the voltage at the plugs.  The air density may lower the voltage requirement for spark there somewhat, though.
Offline CycleRanger
« Reply #7 on: September 29, 2011, 02:03:24 PM »
I know, I was trying to be funny.
I'll try harder.... ;)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: September 29, 2011, 02:16:49 PM »
Sounds good to me. I just need to remember to dress a bit warmer on those cold mornings. The faster you go the colder the windchill temps.
Dukie it's a 76 550K model, they naturally run richer. Maybe that's why I notice it more.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
DH
« Reply #9 on: September 29, 2011, 05:45:29 PM »
Fuel injected engines act this way as well. My cbr 600's engine management reacts in a good way when its cooler outside. Driveability is improved a bit. My old '92 5.0 mustang acted that way too. Guess this is why racers are so keen to enviromental changes when tuning thier engines.
Offline Danno
« Reply #10 on: September 29, 2011, 06:39:56 PM »
that is funny bud my 74 550 requires me to turn the air screws in a quarter turn when it gets cold out to keep performance the same as in the summer my bike loves the heat hates the cold
Offline xsmooth69x
« Reply #11 on: September 30, 2011, 01:41:34 AM »
my subaru is the same way. i have the air coming in from my hood scoop and when it gets cold outside she pulls a lot harder  :)
1975 CB550 (FINISHED?!?!?)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #12 on: September 30, 2011, 09:10:59 AM »
*LIGHTBULB*
So if the air temp is affecting the oxygen intake mixture wouldn't things be running on the lean side? It seems to me if it were running too rich the air part of the mixture would have less affect, possibly? Especially if Danno has to richen is mixture which to me makes sense. I know my bike isn't running too rich probably more lean. I've torn into the carbs many times and made many adjustments over the past year to get the right mix. Currently I would not mess with them any more, I got the bike to strat easily, idle smoothly, pull strongly in all RPM ranges and the plugs have a nice tan color to them. Everything else is by Honda design at this point.
The reason I bring this up is I just had a *voila* moment about my boat. When I first start it and cruise around it runs beautiful. But after an hour it doesn't want to idle as smooth and sometimes I get a slight hesitation when pulling skiers out of the water. Imagine how hot a boat engine gets inside a dog house! there is no cooling in there at all. And the hesitation is usually an indication of a lean mixture correct? Not to get off topic too much but I think I just figured out how to fix an annoynace on my boat that's been bugging me for the past 4 years. My idle screws are too lean! Funny but nobody on hte boat forum I belong to has ever brought this theory up but it plagues a lot of boat stern drive boat owners. I may be on to something. they will think I'm a freakin genious!
As far as EFI cars I've really never noticed it all on any of mine and I've owned lots of them. Mostly slow pokey SUVs and trucks.
« Last Edit: September 30, 2011, 09:13:54 AM by Duanob »
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #13 on: September 30, 2011, 09:37:24 AM »
Danno is probably running slightly lean, you are running slightly rich.
If your performance improves with cooler weather you are probably running slightly rich.
If your performance improves with hotter weather you are running slightly lean probably.
Physics and thermodynamics, very hard to beat.
« Reply #14 on: September 30, 2011, 10:42:41 AM »
A stumble on power application can be from too lean or too rich.  You can tell during power recovery if it was stumbling from to lean, in that it recovers cleanly, like someone had turned it off and then on again.  If it is recovering from too rich a mixture it will burble back to life and miss random power cycles as it returns to power.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #15 on: September 30, 2011, 11:32:08 AM »
Well I think the boat is running a bit lean.
The bike is really fine it just seems to be smoother running cold but it really doesn't run bad at all when it's warm. It's something that only I notice from knowing every little thing about this bike. If someone else rode it on a cool morning and then on a hot after noon they probably wouldn't even notice a difference. But it's a common phenomenon with all carbed vehicles I've ever had and now I know why.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #16 on: September 30, 2011, 12:37:32 PM »
I've often felt moisture (i.e. relative humidity) has something to do with it also. I too have noticed smoother running when cool, but even more so if cool and foggy. No science to back this up, just seems that way.
« Reply #17 on: September 30, 2011, 12:44:31 PM »
same experience with cabureted cars - seem to run better when it rains.
Offline RustyJC
« Reply #18 on: September 30, 2011, 12:45:05 PM »
1971 CB750K1 (original owner)
2007 BMW K1200GT
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #19 on: September 30, 2011, 12:52:12 PM »
For the technophiles - see http://www.engineeringtoolbox.com/density-air-d_680.html.
Rusty
Jeez, you could have sent us directly to #6!  ;D
Offline Goldbug
« Reply #20 on: September 30, 2011, 12:53:53 PM »
I had a turbocharged car running about 25psi of boost. It would usually pull 36lb/min of air according to the airflow sensor. Depending on the weather it might pull 38lb/min and a few times when it was about 32F it pulled 40lb/min.
Every lb/min is about 10hp. So on a typical Summer day it made 360hp. In the Winter it made 400hp. Quite a significant difference. Of course do not expect this sort of disparity on a naturally aspirated engine.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #21 on: September 30, 2011, 02:05:40 PM »
Quote from: Duanob link=topic=96438.msg1074010#msg1074010 Imagine how hot a boat engine gets inside a dog house! there is no cooling in there at all.
[/quote
No air cooling, but lots of water cooling. Unless you have a closed cooling system, you are constantly bringing fresh water into the cooling system.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline nccb
  • 1974 CB750 Four
« Reply #22 on: September 30, 2011, 02:28:39 PM »
i concur with everyones statements.  Mine runs better when it is about 60-75 outside, same as my old golf when i lived in the mountains.  I think they love the cooler weather just as much as we do :P
Offline CycleRanger
« Reply #23 on: September 30, 2011, 06:16:13 PM »
Modern fuel-injected vehicles have MAF (Mass Air Flow) sensors that allow the air/fuel ratio to adjust dynamically.
Offline bender01
« Reply #24 on: September 30, 2011, 07:09:26 PM »
I just rode home tonight. The temp was 70 and its noticeble here in SC. When your bike doesnt run well in MI because its cold you should be on a sled! ;D.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
