Author Topic: '76 CB750F - what are these 2 extra wires on my LH switch?  (Read 977 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: September 30, 2011, 07:42:48 AM »
The reason I ask is that I flipped on my hi beam last night for the first time in ages, and heard this sizzling sound..... yep. At least my hi beam still works, but I can't switch it back to low. Going to try and replace it before Barber if I can find one.
So, what do those two green wires go to?
Offline Trav-i
  • Has finally become an
Re: '76 CB750F - what are these 2 extra wires on my LH switch?
« Reply #1 on: September 30, 2011, 08:09:10 AM »
Since I'm at work I can't see your pic, but I would say they are ground wires.  But without being able to see the pic that's as much help as I can offer right now.
Forum member #9962
1992 GL1500 Interstate
KingCustomCycles.com
« Reply #2 on: September 30, 2011, 08:15:52 AM »
clutch switch?
Offline CycleRanger
  • No comment about being an
« Reply #3 on: September 30, 2011, 08:16:24 AM »
That's for the clutch starter safety switch. You have to have the clutch engaged or be in neutral before the starter will work.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #4 on: September 30, 2011, 08:32:42 AM »
Hmmm.. So can I just use a regular 750K switch (or 550/500 etc for that matter) and not use these? Seems the ones for the F are a little harder to find, and I can probably scrounge up a K one here in town w/o having to order online.
Offline CycleRanger
« Reply #5 on: September 30, 2011, 09:00:52 AM »
Are you talking about the clutch switch or the headlight switch?
The  clutch switches should all be the same.
P/N 35340-329-003
Also used as a front brake switch on some other Honda bikes.
The left controls for a 75-76 K&F are the same I believe.  Dunno about 550 etc.
« Last Edit: September 30, 2011, 09:03:35 AM by CycleRanger »
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #6 on: September 30, 2011, 11:01:15 AM »
So any idea why the hi/lo switch fried? Could it be a bad switch, or do I need to track down a short somewhere in the wiring?
Offline CycleRanger
« Reply #7 on: September 30, 2011, 11:05:48 AM »
Since you say your head light still works I would start with the switch itself.
Open it up and take a look. It's a pretty simple thing. It can be repaired.
Do some forum searching about the left control, there's some threads about it.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #8 on: September 30, 2011, 01:34:56 PM »
Offline jtb
  • An unlikely
« Reply #9 on: September 30, 2011, 03:52:57 PM »
Tugboat, when my 77F got upside down, the only casualty was the mirror mount on the left hand switch.  I got a switch from an earlier K model as a replacement.  It still had the clutch switch wires, the only mod I had to make was to cut a channel in the bottom for the other wires.  In an earlier K model, they ran through the bars.  I'll show you next weekend.
John
1977 CB750F
1985 V65 Sabre
