Author Topic: rear wheel compatibility. cb350 to cb550  (Read 1919 times)
anne
« on: May 12, 2006, 11:51:15 PM »
I have a 78 CB550K.
I am in need of a rear wheel. a few spokes are bent and the hub is cracked on mine. I've been searching around my city (Toronto), but all I've come up with is a CB350 rear wheel. I know  the '77 and '78 Cb 550 rear wheels would be ideal, but with either adding spacers or changing the rear sproket and chain size, using the Cb350 wheel may be compatible????  pleease let me know.
Anne
Offline puppytrax
Re: rear wheel compatibility. cb350 to cb550
« Reply #1 on: May 13, 2006, 03:37:02 AM »
You might try calling Clare's Cycles in Fonthill. They had a pretty good parts guy with lots of used parts connections (in years past).
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: May 13, 2006, 06:28:30 AM »
Anne - I have a rear wheel off a 750 if that would help - I live near High Park.  I have a front for it as well.  I've never really compared it to my 550F's rear wheel, but will.
Let me know if you'd like to have a look, or if anyone here can comment on compatibility, let me know.  If it fits, you can have the wheel.  Anything to get another old Honda on the streets of Toronto  ;D
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline carl550k
  • 76 550k, 99 honda shadow aero
« Reply #3 on: May 13, 2006, 08:21:27 AM »
hey anne, i have a spare set of wheels from a 76 550k. they are pretty rough looks wise.nothing is bent as far as i know,just rusty. by the way im in buffalo ny. about 2 hours south. let me know and ill try to post pics. carl
Offline crazypj
  • I'm brill, me
« Reply #4 on: May 13, 2006, 10:39:30 AM »
350 wheel would probably work but its smaller and lighter than the 550 wheel. It would probably be safer to modify a 750 wheel (the 550 has a crappy brake drum anyway, always cracks up)
PJ
