Author Topic: 1971 CB 500 Four Keep blowing fuses  (Read 3022 times)
Offline 1978CB750
« on: September 30, 2011, 06:09:39 PM »
1971 Honda CB500 4
I charge the one year old battery on the trickle charger over night. The bike starts fine and rides fire for about 10 miles then the fuse blows and the battery is totally dead. Happened a few times now.
Any hints of what I should check?
Offline MoMo
  • Ride like you're invisible
Re: 1971 CB 500 Four Keep blowing fuses
« Reply #1 on: September 30, 2011, 06:19:17 PM »
The first thing I would check is the fuse box, either for corroded terminals  or melted wires as a result of the corrosion...Larry
« Reply #2 on: September 30, 2011, 06:20:57 PM »
Check to see if after 40 years the stock wire diagram is still relevant.
Rather than stating the battery is dead, report the battery voltage that leads you to make such a report.
After installing the charged battery, and it has rested for 2 hours, report the battery voltage before starting and then after starting, at Idle and 1000 RPM increment up to 5000 RPM.
Report the fuse rating you are using in the bike.
Inspect the wires around the steering neck for fraying damage.
72500john
« Reply #3 on: September 30, 2011, 06:23:11 PM »
check your charging system..maybe a case of over charging? which can be caused by dirty connections. aka a dirty connection will show a low battery voltage at the montoring input to your regulator due to voltage drop across the bad connections.  the low voltage seen at the regulator will  result in overvoltage/current and a boiled/fried battery. trust me i know.
« Reply #4 on: September 30, 2011, 09:25:03 PM »
This can also come from a shorted rectifier.
Offline Danno
« Reply #5 on: September 30, 2011, 09:35:52 PM »
I am betting on the rectifier too but two tired has a lot of good things to check to be certain
