Support the site. Your contributions keep this site running.
Now this is the type of stuff I like to read about!! Definatly got me thinking of doing late model EFI on my 1978 CB750 for sure. Looking forward on how you do fuel delivery and engine managment. Im thinking of the basic MAP sensor, Oxygen sensor, Water temp. you doing a IAC? Basically, what basic sensors you plan on using to control the fuel management process of the motor? I love this Stuff!!! You really got my mind thinking of endless possibilities with modern EFI use.Love the out of the box stuff.
What are you using for pistons in the 65mm bore, are they stock Honda CB750?
looking forward to this baby running.video with sound please.
I am also adapting the 600RR stator and rotor so that my charging system can handle all the new electrical demands.
Quote from: 65Ch3v3LL3 on July 18, 2013, 03:34:04 amI am also adapting the 600RR stator and rotor so that my charging system can handle all the new electrical demands. Very cool. I am sure you know this, but you're going to want the R/R from the new bike, too.
Gday Chevelle, you back home..? Hopefully you are . I have my GSXR throttle bodies all set up now, i'll post a pic for you if you are interested, good to see you posting again....
Quote from: Retro Rocket on July 19, 2013, 05:24:01 pmGday Chevelle, you back home..? Hopefully you are . I have my GSXR throttle bodies all set up now, i'll post a pic for you if you are interested, good to see you posting again.... I'm not home yet. I should land in GA around the 1st so just under 2 weeks to go. When I get home I still have to get my new shop in order. I moved all of my stuff into this building just before I headed here so nothing is set up, its just all stored right now. I will be building another 30X60 building to house all my vehicles and then I can arrange my current building so that I can actually do some work. I still have to run air lines, upgrade the 208 service to 200amps and put my epoxy floor coating down. So all that being said I will tinker with my bike some but I will mostly be working on getting the shop setup. I hope to get it all done in a couple of months. I've got a ton of projects that I need to get started!
where at in Georgia? I am in Savannah. can't wait to see more progress by the way!
Wow 2.5 years! I imagine you're ready to come back to to the good old boys of Georgia. When you're back we'll have to go riding sometime! Take care. Thanks for serving
Very ambitious project, Very impressed with the results so far! Looking forward to seeing what you do with the chassis & body.
Quote from: Godffery on July 26, 2013, 08:13:13 pmVery ambitious project, Very impressed with the results so far! Looking forward to seeing what you do with the chassis & body.I'm also working on putting a 05 Duramax and Allison trans in a 52 GMC 1 ton truck to be my shop truck / parts chaser.
