Author Topic: wanted: gas cap latch  (Read 2047 times)
AntiRiceCRX
« on: May 13, 2006, 09:39:43 PM »
i need that little peice that holds down the gas cap
the local junkyard office burnt down and it appears that another yard bought all their bikes, so now i have no resource to get parts from, it sucks, i drove 45min and when i pulled in there was nothing but a huge area of emptyness and a destroyed building which used to be the office/storage for newer wrecked bikes
jsaab2748
Re: wanted: gas cap latch
« Reply #1 on: May 14, 2006, 08:32:44 AM »
I got a NOS factory updated locking latch on E bay recently. I'm pretty sure there's one or two available on auction now, so you might do a search. This is a direct bolt on part, genuine
Honda that uses your ignition key (or just about any key) to open the cap. I see a lot of tanks
around that have had this upgrade in the past. These parts may have been part of  recall, but not sure of that. Anyway, they work good. Good luck with your search.
« Reply #2 on: May 15, 2006, 08:30:39 AM »
The only way to get the original catch is on a used tank. Dave Silver stockes the lock upgrade for £10 (GBP) plus shipping, its actually a 400/4 part
Offline GroovieGhoulie
  • I have to return some videotapes.
« Reply #3 on: May 15, 2006, 08:48:59 AM »
I MUCH prefer the original thumblatch, but they are hard to come across and they are not very strong since they are "metallized plastic".
Reportedly the switch was made because in crashes, the tank would pop open, spilling fuel everywhere and causing a fire hazard.  Also, there was a fellow, in the UK I believe, that got into a crash and he slid forward onto the tank and the opened cap damaged his er...gear, and he had to have one or both nuts removed.  :o :o  The resulting lawsuit helped push the switch to the "locking" gas cap and later, the flat, low-profile gas cap flap.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: May 15, 2006, 08:51:20 AM »
That sounds a bit of an "Urban Myth".  Tried typing it into snopes?
What would you search on?  "Biker loses balls" ....
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Jonesy
  • Shop Rat
« Reply #5 on: May 15, 2006, 12:36:58 PM »
Not quite....
http://www.cmsnl.com/products/chfck-filler-cap_17517300340.html
Apparently CMS still sells the original thumb latches.
AntiRiceCRX
« Reply #6 on: May 15, 2006, 11:46:18 PM »
When i wrecked my CBR600 i screwed up my "gear" pretty bad  ;D
Indiana John
« Reply #7 on: May 24, 2006, 10:58:29 PM »
What bike is this for? I've got a couple of spare 550 tanks with good latches on them.
AntiRiceCRX
« Reply #8 on: June 03, 2006, 07:01:12 AM »
i got the locking gas cap latch, this thing is sweet!
Offline KCs76Cafe
  • Jackson Creek,NC..Deep in the stix of the TRIAD
« Reply #9 on: June 03, 2006, 07:16:40 AM »
Not quite....
Are all of those parts shown at the CMS site still available thru them?
