Author Topic: air box boots  (Read 912 times)
Offline dusterdude
air box boots
« on: October 05, 2011, 06:22:18 AM »
im pondering the idea of installing the stock air box on my 750,question is i need to rejuvenate the boots,how do they come out of the box?all suggestions are appreceted,thanks
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: air box boots
« Reply #1 on: October 05, 2011, 06:30:28 AM »
They should be held on by a groove that is formed in the rubber. Warm them well with a heat gun to soften if needed and simply pull or wrangle them off.
Offline dusterdude
Re: air box boots
« Reply #2 on: October 05, 2011, 06:34:23 AM »
so i would guess they are removable from the plastic tube they attach to?thanks for your reply
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Re: air box boots
« Reply #3 on: October 05, 2011, 06:57:21 AM »
Not sure what the tube is you mention,is it what looks like a velocity stack on the inside.Should all be one piece if memory serves me correctly.  http://compare.ebay.com/like/270822440859?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y
Offline dusterdude
Re: air box boots
« Reply #4 on: October 05, 2011, 07:13:55 AM »
yea thats it,a velocity stack
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline dusterdude
Re: air box boots
« Reply #5 on: October 05, 2011, 07:15:54 AM »
one more thing,i dont think its one piece because if it is i dont see how to get the stack out with removing the boot
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline coma13
  • Lex Talionis
Re: air box boots
« Reply #6 on: October 05, 2011, 07:47:59 AM »
The stack is the boot. It is one part. Part way down the stack there are two raised rings and the inner radius of the hole in the airbox fits in between these two rings.
Basically you just have to squash the diameter of the stack down enough to get the inner ridge to pull out through the hole in the airbox and continue squeezing it so that you can pull the bell part of the stack through the hole. Or you can take the airbox apart and pull them out from the inside.
« Last Edit: October 05, 2011, 07:50:31 AM by coma13 »
They wail and weep,
The march of the sheep,
As they go to that cross on the wall.
KingCustomCycles.com
Re: air box boots
« Reply #7 on: October 05, 2011, 08:03:22 AM »
I highly suggest you purchase new couplers.  I have never encountered a set that were pliable enough to seal properly.  Most are also installed in random, and incorrect, rotation in relationship to the carbs.  I bought a new set for $40.00 and they are wonderful to remove and reinstall and seal perfectly.
Offline dusterdude
Re: air box boots
« Reply #8 on: October 05, 2011, 09:13:39 AM »
thanks guys,im seriously pondering buying new ones
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
