Author Topic: Donny_B 1978 CB750K Build..  (Read 6229 times)
Offline Donny_B
Re: Donny_B 1978 CB750K Build..
« Reply #25 on: January 08, 2012, 06:15:42 PM »
Well, It's been a while since I posted. I was out of the country working. I changed my mind about the front end. I decided to go with a modern GXSR front end instead. I really like the look. Added were:
GSXR Front End
Benjie Oil Tank
MAC Exhaust
Joker Points Cover
Joker Clutch Cover
Joker Side Mirrors
Dyna Electronic Ignition
Rick's Rectifier/Regulator
Offline ryanbfast
  • where does this go?
    • ryanbfast.blogspot
« Reply #26 on: January 08, 2012, 06:34:01 PM »
Looks sweet
69 cb350 X2
73 rd350
67 cl77
cb550 build
http://forums.sohc4.net/index.php?topic=98239.0
Offline lucky
« Reply #27 on: January 08, 2012, 10:21:05 PM »
Very nice bike and good work.
Will like to see it painted.
What did you do to convert the steering stem from the R6 to fit the Honda?
Offline Donny_B
« Reply #28 on: January 08, 2012, 10:45:34 PM »
Thank you very much.. I used the CB stem in the GSXR front end. The are a couple of guys here that did it. I got all the info from this site.
« Reply #29 on: January 08, 2012, 10:48:42 PM »
Hi Donny, its cool that the CB stem is the same diameter, i have one in a GSXR1100K front end, pressed straight in. Is that rear wheel a 17 or 18 mate.?
Offline Donny_B
« Reply #30 on: January 09, 2012, 06:34:41 AM »
Thanks Rocket..... the stem is a tad bit smaller. I placed a shim in there to make it work. Its in there pretty tight.
« Reply #31 on: January 09, 2012, 04:37:37 PM »
Cool, i didn't need any shims, just a decent press to reinstall it. Whats your rear rim size mate.? 17 or 18.?
Offline Donny_B
« Reply #32 on: January 09, 2012, 05:19:22 PM »
There was a member here who heated the stem and stretched it to fit. I wanted to do that too, but I don't have that kind of heat and tool to do that. I couldnt find anyone here in AZ to help me either so I had to shim it. The rear is a stock 17, I wish it was an 18 though. I don't like the way it looks.
« Reply #33 on: January 09, 2012, 06:13:57 PM »
I actually like the 17 on your bike because you've managed to find a higher profile tire to fill up the rear of the bike, looks good.
Offline dawdish
  • Life's better with bugs in your teeth!
« Reply #34 on: April 15, 2012, 07:38:17 AM »
Nice front end, is the front wheel Honda? or something else.
'75 CB400F
'72 CB500 Four
1 CB550 Chappa (barn find)
1 '75 CB550 (barn find)
'81 Guzzi V1000( I couldn't help myself)
Offline Donny_B
« Reply #35 on: April 15, 2012, 10:24:59 AM »
Thanks you, the front wheel is a Narrow Glide Harley wheel....take care. db
Offline Donny_B
« Reply #36 on: June 23, 2012, 03:08:14 AM »
The bike is pretty much done except for paint. I've been overseas a lot. I replaced the seat with a seat I ordered from the boys from Dime City, also added a new headlight. I had some issues with the carbs leaking and not running smoothly. So I ordered bigger jets and new gaskets. The bike runs pretty good now, but it needs to be fine tuned. I don't know how to sync carbs so I'll have to take it to a shop. I also have to find a way to mount a steering stabilizer on it. I want to thank this website for all the info. I've learned so much here.
« Reply #37 on: June 23, 2012, 06:52:18 AM »
Donny,
Compliments to you on the build.  It looks great and the GSXR front end looks awesome.  You will love those radial mounted brakes!
Don
Offline Donny_B
« Reply #38 on: June 23, 2012, 07:32:04 AM »
Donny,
Don
Thanks Buddy... The brakes are great. Stops on a dime.
Offline Donny_B
« Reply #39 on: January 07, 2013, 06:41:15 AM »
Just and update pic..
Offline Donny_B
« Reply #40 on: January 07, 2013, 09:09:07 AM »
Here is another one.
Offline SKTP
« Reply #41 on: January 07, 2013, 07:06:39 PM »
Looking good. Love that oil tank.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Donny_B
« Reply #42 on: January 07, 2013, 10:42:16 PM »
Thanks SKTP.
