Had some time to putz with the bike. My original plan was to change the oil, put on my 350 tank, and jump the bike with my 350 battery just to see if it would start. I never got quite that far. I did test the electrics with the 350 battery and everything seems to be okay. I even got the bike to turn over a few times until the battery went flat.
I swapped out the jet-black oil with a whatever 10w40 I had around. No new filter (yet, might get one today).
I discovered some weird green stuff in the float bowls for #2 and #3. The jets seem a little plugged in those carbs too so I doubt the bike would have started. In the end I decided just to pull the airbox, carbs, and insulators so I can begin working on them.
A look in the carbs revealed the stock 105 main jets and 40 slow jets, so that's good.
Finally I decided I wanted to take a look at the points. These are covered by the crash bar so I decided to take them off. I started working on the left side but the will require the removal of the exhaust to come off and nothing I tried would get the rusty exhaust to budge so I gave up and worked on the right side. There the crash bars came right off and revealed that the points look almost brand new! only a small amount of pitting that I need to file off. Even all of the adjustment screws looked perfect so maybe the whole points plate was changed recently.
While I was down there by the points I couldn't help but stare at the motor. You have to admit, it's one damn good looking motor. It looks like one big, solid, muscular chunk of metal. It seems to convey all of it's internal attributes (reliability, power, etc.) through its outward appearance. I like the look of some of the other japanese inline fours as well, but the cb750 was the first and is still the best.
Next time I work on the bike I would like to get the exhaust off for a thorough cleaning/polishing and maybe start cleaning the carbs.
