Author Topic: 750 K1 Front Damper Valve Forks  (Read 1567 times)
Richard
« on: May 05, 2005, 06:31:24 PM »
Hi folks - I have only just registered with the sohc group am am pleased to see the camaraderie between fellow enthusiasts.
I am currently replacing the fork stanchions on my K1 due to severe pitting that resulted in seal destruction (not the Canadian wood clubbing variety).
On removing the 'valve front damper' part number 51443-273-000 from the stanchion I noted that the one on the left was facing the opposite way to the one on the right tube (ie. chamfered edge facing upward on right tube and downward on left tube.)
The damper is a metal ring approx 10mm high with an external diameter of approx 50mm (these are rough approximations). The ring is chamfered on one inside edge.
I cannot find any detail in the shop manual on which way the damper valve is supposed to be fitted. Any assistance would be greatly appreciated.
Regards
Richard
Western Australia
Offline neckyzips
Re: 750 K1 Front Damper Valve Forks
« Reply #1 on: May 05, 2005, 07:24:25 PM »
hey,
the chamford sides should both be facing down. good luck!
joe
Richard
« Reply #2 on: May 05, 2005, 08:02:45 PM »
Thanks Joe. Didn't expect such a rapid response time.
Richard
Offline kghost
« Reply #3 on: May 05, 2005, 08:11:42 PM »
There was a pretty good post in the FAQ, Dealing with pitting. Smoothing it out with JB weld.
Stranger in a strange land
