Author Topic: Will Honda Cables work with Motion Pro Throttle?  (Read 918 times)
Offline Seeparkfly
« on: October 13, 2011, 11:15:10 PM »
my cables seem fine but I'm changing my handlebars to sportbike bars. i'm interested in purchasing the motion pro push pull throttle but want to use the honda cables. will this setup work?
http://www.motionpro.com/motorcycle/partno/01-0058/
Offline becken
Re: Will Honda Cables work with Motion Pro Throttle?
« Reply #1 on: October 14, 2011, 04:59:18 AM »
I would contact Motion Pro directly. They're good to deal with.
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
« Reply #2 on: October 14, 2011, 05:22:35 AM »
Most likely it will.  My Honda cable works with R6 RH controls no problem.
Offline johnrdupree
« Reply #3 on: October 14, 2011, 10:01:45 AM »
It should.  If you click through to the replacement throttle tube, they claim it's a direct replacement for the OEM Honda tube.  And let us (i.e., me  ;) ) know how it goes because I want to use one of those throttles myself.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline Steve_K
« Reply #4 on: October 14, 2011, 03:49:27 PM »
I have a Motion Pro throttle on my 73 750 using the stock cables, no problem.  Also have it on my 550K cafe racer using Motion Pro cables.
Steve
Steve_K
Offline Seeparkfly
« Reply #5 on: October 15, 2011, 12:01:11 AM »
Thanks for the quick response guys. So I emailed Motion Pro and they responded with:
"I am about 99% sure you will need custom cables built to work with the Motion Pro Throttle 01-0058. If you would like cables to work with the 01-0058 throttle to your machine I will need your stock components as listed in my email below. Another option is you can click the link provided http://www.motionpro.com/motorcycle/partno/01-0058 you can view and purchase the throttle and give it a try with you stock cables and if it does not work you return the throttle back to the website."
Thanks,
Preston Landers
Motion Pro Inc.
Custom Cable Sales
P(650) 594-9600 Ext.119
F(650) 594-9610
Preston@motionpro.com
www.motionpro.com
I wonder why Preston is 99% sure Honda cables won't work. I clicked the replacement throttle link and it says it's a replacement for many honda push pull throttles, equivalent to Honda OE part 53141-300-010 (which fits 750's). One would think since these bikes have been around for so long that this issue must have come up before.
The website leads me to think Honda cables will work, however I'll send Preston another email to confirm and update this post with his response.
@Steve_K, which throttle are you using?
BTW The OEM cables will be treated with AGS Lock Ease 4.
Offline Steve_K
« Reply #6 on: October 15, 2011, 05:53:53 AM »
I used these part numbers (Motion Pro throttle Kit #01-316 or #01-0058).  I had #01-316 on my 86 GIXXER using Mikuni flat slides.  I had the same on my 76 cafe racer using Motion Pro cables.  I could not get 01-316 so I got 01-0058 and I put it on my 73 CB750 using the stock cables.  There is one that looks similar(different number) that works on Yamahas.   I think I paid $15 or less for mine.
Steve
Steve_K
Offline Seeparkfly
« Reply #7 on: October 20, 2011, 07:51:59 PM »
Update:
Preston was still unsure and wanted me to ship my old throttle to their shop to test fit. Thought it was too much of a hassle so I ended up buying the motion pro throttle anyway. When it arrives trial and error time. Will update later.
