Author Topic: How low can you go (sprokets/gears)?  (Read 2265 times)
Offline tanman855
« on: October 14, 2011, 05:28:29 AM »
I want to get a pretty low gear ratio, I want to top out at 100 mph. What is some of the lowest setups they sell? Where can I find it? What chain would I need?
1974 cb750 (cafe in progress)
  • Moderator
Re: How low can you go (sprokets/gears)?
« Reply #1 on: October 14, 2011, 06:56:07 AM »
At a guess you might be looking at 16 front and 60 rear. you might have to buy an after market rear sprocket, try CycleX.
We run 16/ 52 on our drag bike and it still pulls 114 at the end of the quarter.
Sam. :)
Offline tanman855
« Reply #2 on: October 14, 2011, 02:04:23 PM »
Thanks Sam, you have been the most helpful with this. I posted something similar on my other thread and everyone keeps on questing why and not giving me any kind of answers.
Offline tanman855
« Reply #3 on: October 14, 2011, 05:41:46 PM »
Where can I get those parts?
Offline chopped550
« Reply #4 on: October 14, 2011, 07:24:01 PM »
The other thread has people questioning why because you're wanting to top out at a speed your bike should be able to do in factory trim.  If it's only able to achieve 85mph, then you might want to consider not gearing down any more, and possibly installing larger sprockets.  We're just trying to save you some coin in the long run, and determine if there is a problem with your machine elsewhere.
Offline tanman855
« Reply #5 on: October 14, 2011, 10:02:27 PM »
Putting on a larger sproket is gearing down for low end.
Offline mec
« Reply #6 on: October 15, 2011, 12:18:07 AM »
for streetracing once I used 14t to 17t sprokets.
but with small sprokets you are doing no good to the chain and bearing (behind the sproket) as well.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline tanman855
« Reply #7 on: October 15, 2011, 08:52:01 AM »
Could I do 17 and a 60
« Reply #8 on: October 15, 2011, 10:06:07 AM »
Do you plan to do much riding on freeways and interstates? If so, the 17/60 may be too low. I'm running a 16/48, and cruising at 75 MPH, I found myself looking for 6th gear. A 17/52 would be a tiny bit lower than 16/48. (3.00:1 vs 3.058:1)
Online Stev-o
« Reply #9 on: October 15, 2011, 10:17:36 AM »
Have you ever ridden the bike?  Just trying to more info from you to help
« Reply #10 on: October 15, 2011, 10:22:59 AM »
mec
Good point...I always recommend a larger rear sprocket. You can also have problems with the swingarm with the smaller countersprocket. With a real large rear sprocket you have limited engagement with the countersprocket. Hmmmm. Always trade offs. I'd say a 3.5:1 ratio is about as high as I would go though I think Frank (754) once ran a 14 front 70 rear.  ???;) ;) ;D
« Reply #11 on: October 15, 2011, 10:41:09 AM »
 I never ran smaller than 17 on the front if I remeber correctly.. I have a 16 from a KO but hesitate to use it if running it hard.
 How big can you go probablyat least 80 if not 100.
 Dont know why you have 2 threads, told you right off the bat in the  other , it uses same chain, only longer and there are many suppliers, just search on your computer.
 Failing all that you can go to a bearing or power transmission place, oerder a blank in any size you desire, bore the center, and drill the 4 holes to mount it. When you go real big though you may want aluminum, its a 1/3 the weight of steel.
« Reply #12 on: October 15, 2011, 11:13:35 AM »
The only reason I'm running a 16 is I couldn't find my 17, and I had to have the bike ready for the relay. I think a pack-rat made off with the 17. >:(
« Reply #13 on: October 15, 2011, 11:42:26 AM »
...a CB750 "stunt" bike. Very interesting. ;D
Offline tanman855
« Reply #14 on: October 15, 2011, 09:37:06 PM »
Just ordered a custom gear to get machined I have 18t in the front so I ordered a 56t back wich comes out to 3.11 gear ratio!
