Author Topic: Help with chopped wiring system  (Read 1049 times)
darkdragon11487
« on: October 20, 2011, 01:59:59 PM »
OK what im trying to do is wire my 1972 Honda CB750 so that i have no starter and no battery so its kick start only. I've heard of capacitors that do this but im not sure how it would be wired with the stator, rectifier and regulator please any help would be greatly appreciated
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: Help with chopped wiring system
« Reply #1 on: October 20, 2011, 03:42:56 PM »
I know the Triumph bobber guys do this but I believe they use a "kit" of unique components instead of adapting the existing system.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: October 20, 2011, 03:44:30 PM »
You will not be able to eliminate the battery with the stock alternator. The stock alternator uses an electro-magnet that requires 12 volts to generate the magnetic field that makes the alternator work. There may be an aftermarket solution, but I'm not sure. Your bike won't even run with a weak or dead battery. Newer charging systems use a permanent magnet in the alternator.
Eliminating the starter is easy, just need to plug the hole in the case where the starter gear pokes through.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline rev.buttons
« Reply #3 on: October 20, 2011, 04:05:25 PM »
I agree. I know cycle x sells them and you can find the plug on ebay too
Cb750k4
1977 yamaha xs750
1974 ironhead
« Reply #4 on: October 20, 2011, 04:24:15 PM »
You will need to convert the charging system to a permanent magnet type, or convert the ignition to magneto type.
Stock ignition needs electrical power to make spark.
Stock alternator needs some battery power to make any electrical power. (has electromagnet instead of permanent magnet.)
Don't believe the BS at cycle X about 2 hp used by the stock alternator.  One hp=745 watts.  There is just no way that the stock alternator requires 1490 watts to make its rated 210 watt output.  (14% efficiency??  I don't think so.)  They are seriously gilding the lily for that claim.  (Probably in a desperate effort to justify their $450 sales price, I'm guessing.)
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #5 on: October 20, 2011, 05:50:12 PM »
I thought one HP was 746 watts?  Just to keep you sharp :-)
« Reply #6 on: October 20, 2011, 06:26:14 PM »
Slacker.
1 HP = 745.69987  (For the picky ones.)
 ;D
