Author Topic: Biggest Rear Tire ? that will go on a 78 cb750f?  (Read 3054 times)
Offline joelt85
« on: October 16, 2011, 03:05:29 PM »
Ive heard of guys putting wider rears on , wanted to know what the biggest size you can put on the rear is without having any interderence , thanks
Joel
Re: Biggest Rear Tire ? that will go on a 78 cb750f?
« Reply #1 on: October 16, 2011, 03:50:01 PM »
On a 78 you can go at least two sizes over stock with no rubbing. You will notice that the center of the tire will wear flat after a while since the rim is too narrow. You will develop a step between the ecenter tread and the sidewall, when you make a turn you will feel the step. You can find threads covering this in detaol if you do a search. I went down to one size over and the bike handles better.
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #2 on: October 16, 2011, 04:20:42 PM »
I'm running a 110 on the back of my 500 and I'm noticing that the tireis very crowned, almost pointy. Unless you get a wider rim I would stay as close to stock as possible.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Gibblet
« Reply #3 on: October 16, 2011, 05:37:11 PM »
I know it seems better to put a wider tire on, but I would stick with the stock 100 or 110.
1978 CB750f
1980 CM400t
Offline Roach Carver
« Reply #4 on: October 16, 2011, 07:45:59 PM »
fat tire craze is over, put the right tire size on and you will be happier.
« Reply #5 on: October 16, 2011, 08:16:54 PM »
I have a 120/90 on the back of my K4, bought it that way. No problems.
Offline DORIGTT
« Reply #6 on: October 16, 2011, 10:52:30 PM »
What's the reasoning for NOT going with a larger rear wheel / tire combo?
In looking at the Ducati Sport Classic line, they ran a 120 front (3.5x17 wheel) and 180 rear (5.5x17 wheel).  Not that we'd want to run that size, but a wider wheel out back (how big is the question) and wider tire would fill out the look a bit right?
If you upgrade to the better swingarm bushings out back, fork brace and decent steering bearings, the chassis can take it right?
« Reply #7 on: October 16, 2011, 11:38:02 PM »
I put a 4.5 inch rear Suzuki rim on the back of my K2 just for a look {same size axle}, it had a 180 slick {wheel came of a 80's GSXR race bike} and it fit in with a tiny amount of room left each side, you would need an offset front sprocket for this to work on the street and probably a 160 street tyre would suffice.
« Reply #8 on: October 16, 2011, 11:54:55 PM »
If you are using the stock rear rim/wheel (1.85) 4.10x18 is the largest that properly fits it.
If you are changing the wheel rim width to match the tire, then you might consider the chain width (630?) and type of chain guard you are using.
You might state what stock bits you plan to use and how much modification you wish to tolerate/perform.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #9 on: October 17, 2011, 03:54:52 AM »
Actually, fat front and rear are now popular.  I think Exile and the Europeans were ahead of their time on that one.  Of course, the old Harleys used interchangeable tires front to rear and both were "fat" by 1970's Honda standards.  I have used 130-90-18 rear and 110-90-19 front with success on 70's K and F models.  No fender on the front and hardtail on the rear.
« Last Edit: October 17, 2011, 03:57:03 AM by Rigid »
Offline lrutt
« Reply #10 on: October 17, 2011, 05:11:53 AM »
got a 130 on my K6 for the last bazillion years, Very close to chain guard but no rubbing.
Offline DORIGTT
« Reply #11 on: October 17, 2011, 09:07:30 AM »
I'd like to run a wider wheel to prevent the 'balloon' effect on the larger rear tires when they are being pinched in .
« Last Edit: October 17, 2011, 04:44:00 PM by DORIGTT »
