Author Topic: Joker Brake Strap  (Read 1022 times)
Offline Donny_B
Joker Brake Strap
« on: October 19, 2011, 06:25:19 PM »
Hello...I would like to purchase the Joker Brake strap for my 1978 CB750K. I'd like to know if it would fit because the highest year on the webpage says 1976 CB750K. The frames look Identical to me. Can anyone tell me if it will? Thank you....db
http://www.jokermachine.com/itemcafe2004.asp?ItemID=811&CategoryID=85&Placeholder=
Hinomaru
Re: Joker Brake Strap
« Reply #1 on: October 21, 2011, 08:40:18 AM »
Well, unfortunately it won’t fit your ‘78 750K due to the part number difference. Here's why:
The Joker website lists that brake strap as:
Honda part no: 43431-286-010
The part number cross reference shows that 43431-286-010 will only fit the following Honda models:
CB350 A MOTORCYCLE, JPN, VIN# CB350-1000001
CB350G A MOTORCYCLE, JPN, VIN# CB350-5000001
CB350K2 A MOTORCYCLE, JPN, VIN# CB350-2000001
CB350K3 A MOTORCYCLE, JPN, VIN# CB350-3000001
CB350K4 A MOTORCYCLE, JPN, VIN# CB350-4000001
CB500T A MOTORCYCLE, JPN, VIN# CB500T-1000001
CB500T A (76) MOTORCYCLE, JPN, VIN# CB500T-2000001
CB550F A MOTORCYCLE, JPN, VIN# CB550F-1109886
CB550F A (76) MOTORCYCLE, JPN, VIN# CB550F-2000003
CB750K A (76) MOTORCYCLE, JPN, VIN# CB750-2540001
CB750K0 A MOTORCYCLE, JPN, VIN# CB750-1000001
CB750K1 A MOTORCYCLE, JPN, VIN# CB750-1044650
CB750K2 A MOTORCYCLE, JPN, VIN# CB750-2000001
CB750K3 A MOTORCYCLE, JPN, VIN# CB750-2200001
CB750K4 A MOTORCYCLE, JPN, VIN# CB750-2300001
CB750K5 A MOTORCYCLE, JPN, VIN# CB750-2500001
CL350 A MOTORCYCLE, JPN, VIN# CL350-1000001
CL350K2 A MOTORCYCLE, JPN, VIN# CL350-2000001
CL350K3 A MOTORCYCLE, JPN, VIN# CL350-3000001
CL350K4 A MOTORCYCLE, JPN, VIN# CL350-4000001
CL350K5 A MOTORCYCLE, JPN, VIN# CL350-5000001
SL350 A MOTORCYCLE, JPN, VIN# SL350-1000001
« Reply #2 on: October 21, 2011, 08:53:08 AM »
 I will try to look today, check some parts.
 The 77/78 arm I think is tubing with flattened ends.
 Is the Joker a flat bar style or rod ends?
Offline Toxic
« Reply #3 on: October 21, 2011, 10:08:09 AM »
77/78 swingarm is longer, that might be an issue
« Reply #4 on: October 21, 2011, 07:16:42 PM »
 76 and down K, the anchor bracket has a 5.5mm slot.. the arm is 14 1/4 inches between centers.
 77/78 K the anchor bracket has a 5mm slot and the arm is 12 1/8 inches long between centers..
 this will be a problem...
