Author Topic: Cracked Side Cover Repair  (Read 1274 times)
Offline Grabcon
« on: October 22, 2011, 09:06:29 AM »
I have several questions about welding plastic side covers for these CB Honda's.
First does it really work?
If so what type of plastic welding rod is used?
And is there a good thread on this forum that goes into some details on how to?
I have not been impressed using high end epoxy.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline Patrick
Re: Cracked Side Cover Repair
« Reply #1 on: October 22, 2011, 09:20:32 AM »
Super Glue and baking soda react to create strong, sandable, paintable bond. I have used it to fix several side covers from several bikes.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
« Reply #2 on: October 22, 2011, 09:39:14 AM »
I have sucessfully used woven glass mat(as against chopped strand) in epoxy before but to be honest if the panel has got brittle enough to crack you are better off buying new from LPM
http://stores.ebay.com/L-P-M-Plastic-Motorcycle-Parts
Offline Thunder
« Reply #3 on: October 22, 2011, 10:41:18 AM »
I took an old sidecover that was totally stuffed, broke it into bits and into a jar with acetone, a day later it had melted into a  treacle like goo.
On the reverse side of a cracked cover i made a shallow V and smeared the goop in.
Because its the same material it actually melts its way onto your side cover becoming a very zen like "one" with it.
I have not found it to break yet, even though the cover rubbers are hard as hell.
Hope it helps
Offline racemx51
« Reply #4 on: October 22, 2011, 11:20:41 AM »
Go to a paint store that sells SEM products and buy a tube of problem plastic repair material... Use that with some net tape... Thats what we use at my body shop for anything like this...Or cracked bumpers... Stuff works amazing..
