Slooooow , hate this
i want stuff finished now , right now !!!!!!!
Engine :
-Bottom half , oiler for primary , and mountingpoint for primary tensioner done
-Top half , holes for Cylinder sleeves drilled out to accept 750 sleeves , hole for starter motor welded ,and notches for camchainguide done.
-Cylinders , sleeves pressed in and honed for 65mm pistons , piston tops machined to fit with stroke height and head ,done
-head , welded up top edge to fit with 550 rocker cover , done
-oilcooler adapter plate fitted ( 80 something 450 )
Engine to do :
Pocket pistons for valves
Porting
Bigger valves ?
Due to poor planning I'm kind of stuck , i forgot to order bearings for the crank , stupid,stupid,stupid , and now at david silver they re out of stock , so i cant put the cases back together
Also waiting for :
Spokes
Camsproket
Camchain
Oilsump (650 to allow primary tensioner)
Cam
Ignition
Headlight
Chain and sprockets
So while i Wait I'm redoing the paintjob om the tank and cauling
