Author Topic: The 740 cc"Nazgul "cafe , its awakening  (Read 59620 times)
Offline Emokid
  • Easy you say ? Now where's the fun in that ?
Re: A 550f transforming into the 798 cc"Nazgul "cafe , acetone complication
« Reply #50 on: November 16, 2011, 12:06:23 PM »
Last layer of fiberglass is on the tank  ;D
I have been sanding down the bumps every two layers ( i now have six ) to avoid getting a major problem in the end , seems to work quite well , before the last layer the tank felt reasonably smooth , so i don't think i will need very much bondo , fingers crossed .
The petcock bunge is in place , i used the old one witch i cut out , sanded down the metal left around the pipe , drilled some holes in it and sandwiched it in between some layers of fiberglass .
On the first pic the filler neck is in for a test fit , it is approx 3,5cm high , and approx 1 cm will be visible over the tankbody .
in the lower 2.5 cm i cut some grooves with an angle grinder to increase ( at least in my mind ) the bond to the epoxy , then i put it upside down in a hole i cut for it in some styrofoam ,with the bottom part protruding and made a collar with fiberglass , it will be something like 1,5 cm wide , and tomorrow i will fuse it to the tank with epoxy .
And BTW sanding fiberglass is some itchy  sh.. :(
-76 550f ,transforming into the 798 "Nazgul" cafe
http://forums.sohc4.net/index.php?topic=97563.0
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #51 on: November 16, 2011, 12:18:32 PM »
Itchy indeed.
Offline hapakev
  • Your Standard
« Reply #52 on: November 16, 2011, 12:48:12 PM »
That looks good, I'm glad to see it back together.  I was a little worried for that beautiful tank.
Smoking Jack
1978 CB750F(ish)
Offline lordmember1969
« Reply #53 on: November 16, 2011, 11:57:54 PM »
Hey how old are you? I always read Norway has a great educational system and allows kids to take paths in their career choice at an early age. You have some serious skills.
 Thanks , but I'm to old for that anyway  :)
Hi:) Looks great, fun to See another Norwegian on here. . Where are you located in Norway?  :)
Thanks  :)   I'm from Lillehammer , what about you ?
Namsos :)
1977 CB 750 SS Cafe
1977 CB 750 Basket case
1971 Mustang Grande
1928 Model A Pheathon Hot Rod
1977 Harley Custom FXE
http://forums.sohc4.net/index.php?topic=70333.0
Offline Ouch
« Reply #54 on: November 17, 2011, 02:21:44 PM »
what a minute  :o are you putting a tank inside the glass shell?
« Reply #55 on: November 17, 2011, 06:43:22 PM »
ouch!!!
Offline Emokid
« Reply #56 on: November 17, 2011, 10:33:41 PM »
Nope , only thing left of the old tank is the fixing points , and sort of skeleton of the backbone tunnel , otherwise only fiberglass
Offline jgmmgood
  • You don't need proof when ya got instinct.
« Reply #57 on: November 18, 2011, 07:53:07 AM »
Looking back on the need to cut open the tank to remove the styro, I would have thought it may have been easier to deal with the filler tube and fuel bunge at that point rather than waiting until it was all pieced back together.....Just a thought.  Would you agree?
Lookin' is for free, Touchin's gonna cost ya sumthin - Chaz Michael Michaels.
Offline Emokid
« Reply #58 on: November 18, 2011, 09:49:52 AM »
Agree :) , and thats just what i did , put in the petkock bunge when the tank was apart , but the filker neck was easier to puy in afterwards .
Now the tank is actually finished , only thing that remains is the sanding. And smoothing , then primer and paint .
Next project now is the seat
Offline Ouch
« Reply #59 on: November 18, 2011, 10:50:48 AM »
are you coating the inside of the tank? or gas to resin only?...
Offline Emokid
« Reply #60 on: November 18, 2011, 12:13:41 PM »
I will use caswell tank liner to avoid the tank turning into goo .
So now i have fixed the fillerneck to the tank and laid one last layer of weave on the bottom and tunnel , so that pretty much completes the tank build  :D
Just sanding , and priming left ......
Went over to the paintshop (witch is litterally the next door neighbor to my garage ) and talked to them about the paintjob , and the guy behind the counter asked me what kind of bike i was restoring , i told him it was a 76 cb 550 , next question was : are you going cafe style ?  :)
That led to a long chat and they guy was totally into it, witch is never bad when you want some help with stuff , deal is i drop of the tank sometime next week , and they will prime it along with some other stuff during the week  ;)
Next project now will be the seat , need to get that rear hoop welded in place , and start laying out the fiberglass , more on that later
« Last Edit: November 18, 2011, 12:24:18 PM by Emokid »
« Reply #61 on: November 19, 2011, 05:15:30 AM »
Hi.. Let me know where you find the caswell tank liner, have been looking at it to use on my oiltank.  Do they sell it in Norway? Tank is looking god:)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline onepieceatatime
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
They have a technical forum as well.
Yo Yo Emo, I have been motivated by your glass. I have done some fiberglass before but for my bike I have been so focused on aluminum...but have no welding or metalworking skills. I have had an idea of what I want to do with my rear hugger for a year now (out of aluminum) and now, I will get it done. Using fiberglass.
Offline Emokid
« Reply #64 on: November 22, 2011, 01:42:30 PM »
Hi , i contacted caswell in the us , and they directed me to caswell europe in the UK , the tankliner is 45 £ plus shipping , witch is almost as much >:(
But they could combine shipping of up to four units for the same price , so let me know if you want to share shipping costs  :)
Offline Emokid
That is way cool , pictures please  :D
« Reply #66 on: November 24, 2011, 12:16:21 AM »
Will be happy to, just pm me when you get to ordering :)
1977 CB 750 SS Cafe
1971 Mustang Grande
Offline Emokid
Re: A 550f transforming into the 798 cc"Nazgul "cafe , frame cleanup
« Reply #67 on: November 27, 2011, 08:40:43 AM »
weekend and time for some work  :)
since the tank is done (for now) i need to build my seat and cauling next , but to do that i need to finish the frame modifications .
so i started cutting , away with everything sticking out , removed the mounting plates for the rear footpegs , the shock upper mounts (way to ugly in their original shape )and assorted brackets and fastening points , for now this is what i ended up with :
Offline Emokid
« Reply #68 on: November 27, 2011, 08:43:30 AM »
I also got the drawings for my new upper triple from Durgam today ,and its looking f...ing awesome with the integrated motoscope mini instrument , cant wait to lay my hands on the finished product  :)
Offline KB02
« Reply #69 on: November 28, 2011, 07:33:05 AM »
so i started cutting , away with everything sticking out... the shock upper mounts (way to ugly in their original shape)...
What are you going to do for new shock mounts?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Emokid
« Reply #70 on: November 29, 2011, 04:09:09 AM »
I will reuse the bolts from the old mount and make some new ones that flow better with the lines of the frame , at least thats the plan :)
Offline Godffery
  • Godffery's Garage
« Reply #71 on: November 29, 2011, 05:45:49 AM »
You're a rather ambushes fellow and your efforts seem to be paying off.
Do you have any drawings of what you want the finished bike to look like or are you shooting from the hip?
Offline Emokid
« Reply #72 on: December 01, 2011, 11:49:48 AM »
I have a complete set of drawings ...... in my head , and they are constantly changing
Offline Emokid
« Reply #73 on: December 01, 2011, 11:57:13 AM »
Today i welded the frame together , got the rear hoops on , and new mounts for my rearsets .
The hoop going up over the frame will be visible with the seat tucking in underneath it , and the cauling as a separate piece behind it , don't know if that made any sense though  ;D , in my head its clear at least .
i wanted to put the rearsets on the old passenger peg mounts , but i think the original ones didn't look to good , so i cut them of , leaving the tubing , and then welded in two pieces of roundbar witch i had machined to fit the bolt of the new pegs .
And as a comment to the last picture ,Yes i am that anal , i really smoothed out the kickstand , i need to get my head checked ,i know  :P
Offline lucky
Re: A 550f transforming into the 798 cc"Nazgul "cafe , rear frame new look
« Reply #74 on: December 01, 2011, 12:56:26 PM »
All the work you have doing look very good so far.
