Author Topic: Oil Level Dropped, Then Rose  (Read 1738 times)
Offline Tree
  • CB750K5
« on: October 22, 2011, 12:53:54 PM »
I was surprised to see my oil level abruptly down a quart, but I added a quart to bring in up to the Max level.  About a week later I've noticed it's about a quart overfilled.  This leads me to think I might have some type of intermittent circulation problem.  Has anyone else experienced anything similar and determined the cause?  (It's a '78 750K).
« Last Edit: October 22, 2011, 12:55:41 PM by Tree »
Re: Oil Level Dropped, Then Rose
« Reply #1 on: October 22, 2011, 01:11:50 PM »
When it sits a while, oil can leak past the check valve in the oil pump.. then tank appears low.
 When you start it , it comes back up for a while. It may happen only occasionaly at first..
 Quart high wont hurt, but I wouldnt do it if its not getting to full temps every ride..
Offline singedebile
« Reply #2 on: October 22, 2011, 06:13:33 PM »
which is why, (and correct me if im wrong) its better to check the oil when when your engine i warm.
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline Tree
  • CB750K5
« Reply #3 on: October 23, 2011, 06:45:51 AM »
I have  been checking it first thing in the morning before riding.  The level had always been very consistent up until recently.  Guess I'll start checking it after it's warmed up from now on.
More from curiosity, every heard of the check valve becoming bad enough that it had to be repaired or replaced?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: October 23, 2011, 07:27:25 AM »
Actually, the best time to check oil level is immediately after a ride. That will give you a true reading of the oil level in the tank. And yes, there is a rubber tip on the check valve, that's what goes bad and starts to leak. As far as I know, that part is no longer available.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #5 on: October 23, 2011, 07:50:29 AM »
Actually the best time to check oil level is immediately after a ride.
That is how I check my oil too.... ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #6 on: October 23, 2011, 08:55:06 AM »
10-15 minutes after a spirited ride is what the manuals say.
Offline Tree
  • CB750K5
« Reply #7 on: October 23, 2011, 03:13:39 PM »
"Spirited ride"  - is that a Halloween thing? :(
Offline Honda George
  • Been riding for 44 years
« Reply #8 on: October 23, 2011, 04:01:28 PM »
I replaced the rubber check valve twice in my 72 750 when the part was still available.
Honda George
1973 CB750 K-2, 1985 Honda Shadow VT1100C,
Offline 74750k4
« Reply #9 on: November 20, 2011, 06:38:03 PM »
George,
Can you tell me some symptoms you had that made you change that twice?  I get smoke and drips of oil out the pipes during warm up now on my 74. I had swapped the oil pump with one from a 78 case. No problems until I did that.  I guess I'm going back to the old pump. What is so special about that rubber check valve tip? Maybe a silicone rubber piece would last longer.
Martin
Offline Hondawggie
  • Flimmy-Flammy, Hambone-Sammy -- I'm a Bigole
« Reply #10 on: November 21, 2011, 04:09:33 AM »
its engrish
 or this
    “Operating Instructions for Motorcycle…
    “When driving please you keep the relaxing moon and wear comfortable clothes, obey the traffic rule and prohibit making the moon impatient…”
http://www.globalization-group.com/edge/2010/07/motorcycle-translation-bloopers/
« Last Edit: November 21, 2011, 05:14:03 AM by Hondawggie »
