The steady higher load of 2 ohm coils would for sure melt the fuseholders, rather than blow the fuse IMHO
The fuseholder can only melt due to a poor connection, which is what generates the heat.
Technically, this is not true. Consider this:
The fuse link is a metal alloy of zinc, copper, silver, aluminum, or alloys to provide stable and predictable characteristics.
The cross section of the fuse link is sized so that it generates internal heat based upon current flowing through.
Ergo, a fuse passing current beyond its rating generates enough internal heat within the link the melt the metal alloy.
Passing ANY current within the fuse link generates some heat relative to the amount of current passing through the link.
Let's say the fuse link melts at 600F. If you run the fuse slightly below the rating, it may attain 500F, and this heat will be radiated and conducted to any path available; end caps, fuse clips, and wire connection and also into the surrounding atmosphere.
Normally, the main fuse runs at about 10 amps which is about 2/3 of the fuse rating. It will run warm (won't burn your thumb), but still below fuse melting temperature and also below the temperature where the plastic melts.
Run a 15 amps fuse at 14 Amps, and the fuse link gets very near its melting temp., perhaps 400F-500F which is conducted to the fuse clips and sufficient to melt most plastics (and blister thumbs).
I do agree that the stock fuse block in the stock bike is normally damaged by poor or deteriorated connections. However, when electrical modifications are made to the bike, don't be surprised if the stock engineering of the electrical system can't handle additional loads placed upon it.
Certainly 3 ohm coils qualify as and electrical modification, as would higher watt headlights, heated vests, beer coolers, and hip-hop thump boxes.
