Author Topic: Gah!! No starter button!!  (Read 1857 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: October 27, 2011, 10:37:56 AM »
Ugh... at every turn on this CB500 rebuild it's been something.......
The latest is that when I was hooking up the throttle cables last night, I found that the starter BUTTON is missing from the RH switch (which is in otherwise good shape). How can that be? I carefully checked on the ground to make sure it wasn't ME that lost it. Nope - missing when he brought it in. How did that happen? Seems to me that  they're too "long" to just pop out. The plate behind it in the switch is intact and screwed in. Sorry - left my camera at home so no pix.
SOOO..... no way in h3ll I'm gonna try to start this thing for the first time after rebuild by just kicking it!! And before I go and replace the whole switch, does anyone have an old broken RH switch that I can have the button out of?
Offline Gordon
  • 750K1, 550K2
Re: Gah!! No starter button!!
« Reply #1 on: October 27, 2011, 10:49:32 AM »
Those starter buttons get very brittle with age and often just shatter and fall out.
Not sure why you're so against kick-starting after a rebuild, though.  If the work was done right it should kick-start just fine.  If it wasn't done right you'll kill the battery trying to use the electric start.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: October 27, 2011, 11:09:01 AM »
Just hedging my bets, you know :)
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: October 27, 2011, 11:15:34 AM »
But how satisfying would it be to kick-start an engine you rebuilt yourself? 8)
Offline phil71
« Reply #4 on: October 27, 2011, 11:16:05 AM »
just ground the yellow/red with a jumper wire for now
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: October 27, 2011, 11:19:01 AM »
Or bridge the terminals on top of the solenoid with a screwdriver.  Sparks make for better dramatic effect.
Offline phil71
« Reply #6 on: October 27, 2011, 11:32:03 AM »
someone likes frankenstein movies.....
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: October 27, 2011, 11:41:12 AM »
It makes for a good Halloween-themed rebuilt bike start-up.
Turn down the lights, play spooky music, bridge the terminals to turn the starter and make sparks, and scream "It's alive!  It's alive!!!!!". ;D
Offline WhyNot2
  • I'm finally an
« Reply #8 on: October 27, 2011, 12:10:45 PM »
 :) :) :) :) :)......laughing @ gordon not you tug..............feel your pain on the switch.
Offline johnrdupree
« Reply #9 on: October 28, 2011, 06:41:22 AM »
I bought my 550 without the starter button.  When it came time to start it for the first time I crammed the end of a plastic pen in the hole.  Worked fine.  After all the carb cleaning and valve adjusting and cam chain tensioning and timing and carb syncing it starts on the kicker without fail (Well, almost. Now that the weather is cooling down I'm having to puzzle out the 50 degree starting procedure.)  So, don't let a missing starter button stop you, grab the nearest Bic and crank that thing up.
Good Luck,
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #10 on: November 01, 2011, 08:35:30 AM »
This wouldn't be a problem if it wasn't for a customer. Granted, he probably brought the thing in with the button missing. But I can guarantee you that this dude is an electric start kinda guy. So...... anyone got a busted old switch that I can have the button out of?
Offline Hush
« Reply #11 on: November 01, 2011, 08:43:21 AM »
I feel your frustration dude, used my horn to hail a guy the other day and when I got home realised that somewhere along the way half of the little black button fell off!
Like Gordon says they get brittle and disolve. :)
Offline johnrdupree
« Reply #12 on: November 01, 2011, 08:46:21 AM »
While researching Yamaha XS750s (for a bike I'm already regretting not buying) I ran across this vendor:
http://www.freewebs.com/kibokojoe/
I don't know if it will work on a Honda, but it wouldn't hurt to ask them.  Or see if they would willing be to add a Honda button to their lineup.
Good Luck,
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
bollingball
« Reply #13 on: November 02, 2011, 05:04:55 AM »
Tug scroll down to starter/horn button This worked on my 750. don't know about the 500. I did have to do some filing for it to work.
http://www.partsnmore.com/parts/honda/cb750/?filters[fitting]=custom&filters[category]=electrical
