Author Topic: Oil Filter Spacer?  (Read 1696 times)
Offline Steven.Burns
  • Beer and Bikes
Oil Filter Spacer?
« on: October 28, 2011, 06:52:14 PM »
I just changed my oil for the first time tonight and once I put everything back together I found a spacer in the used oil pan. What is it and where does it go? It's not in the manual
1978 CB750F3 -Scrambler/ tracker or something of the sort  http://forums.sohc4.net/index.php?topic=97025.msg1083788#msg1083788
Offline Johnie
Re: Oil Filter Spacer?
« Reply #1 on: October 28, 2011, 06:56:47 PM »
Ah, the ol' spacer...at least you have one. Most of the bikes I get have it missing. That spacer goes between the filter and the spring. It is used to keep the spring from digging into the rubber on the oil filter. I don't think you would need to take the filter off and put it back on there unless you did not add the oil yet. Just put it back on next change.
Modified: I am taking it for granted it is the washer for the filter. But you should know there is also a crush washer on the drain plug too. That one is a not as big width wise as the filter washer.
« Last Edit: October 28, 2011, 06:58:50 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
  • Beer and Bikes
« Reply #2 on: October 28, 2011, 07:30:11 PM »
sweet thanks. Its just a pain in the ass taking the filter off and getting oil everywhere for one little spacer. glad its not a big deal  ;D
« Reply #3 on: October 28, 2011, 07:34:25 PM »
even with a full sump you only drop the filter housing worth of oil,catch it in a clean container and pour it back in,that way you can say you did it properly,,i would expect a shop to throw out that washer if they found it and knew what it was.
Offline raymond10078
  • Just learnin' as I go . . . .
« Reply #4 on: October 28, 2011, 07:55:14 PM »
Just a note of caution.  Your spacer - does it look like a washer?
I recall that the 78 CB750F had a spacer that looks like a collar - due to the added oil filter "heat sink" that was added for that bike.  This collar is needed - otherwise the oil isn't passed through the filter.
See pic - are you talking item 5 or item 9?
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
  • Beer and Bikes
« Reply #5 on: October 28, 2011, 08:22:31 PM »
#9 is what I forgot to put in the bike. I didn't see #5 in there but didn't really look all too well. I'm just going to put it in tomorrow just to be safe. Also I only saw one large O-ring
« Reply #6 on: October 28, 2011, 08:28:21 PM »
Did #7 come off with the filter housing?  If not - only one large o-ring.  Still should have replaced one large and one small o-ring.  Some filters don't come with the o-rings, though.  The Honda filters usually do.
  • Beer and Bikes
« Reply #7 on: October 29, 2011, 01:54:18 PM »
#7 did come off but didn't look for an o-ring. It probably is still on the bike. I'm about to go fix it when I get home to put the spacer back in. I'll let you all know what kind of problems I get into now.
  • Beer and Bikes
« Reply #8 on: October 29, 2011, 06:59:17 PM »
Alright, I finally got it all put back together the RIGHT way with everything there. Easier than I expected :)
Offline jtb
  • An unlikely
« Reply #9 on: October 29, 2011, 08:48:55 PM »
You have to get an extra o-ring when you get your filter.  The washer #5 is no big deal.  I didn't have one for 8 years.  finally ordered one for the hell of it.
1977 CB750F
1985 V65 Sabre
  • Beer and Bikes
« Reply #10 on: October 29, 2011, 09:21:37 PM »
I did actually have the o-ring. They came with the honda filter. But I don't have the washer.
Offline jtb
  • An unlikely
« Reply #11 on: October 30, 2011, 08:30:18 AM »
The honda filters come with one large and one small o-ring.  I always order the 2nd large o-ring with the filters as one goes behind the base (#7) as well as the one which goes between the filter housing and the base.
1977 CB750F
1985 V65 Sabre
