Author Topic: Keyster carb parts are now better than OEM  (Read 1268 times)
Offline fmctm1sw
« on: November 02, 2011, 11:14:24 AM »
Yep.  Don't take my word for it, look here:  http://www.siriusconinc.com/faq.php#name_9
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline lone*X
Re: Keyster carb parts are now better than OEM
« Reply #1 on: November 02, 2011, 11:22:43 AM »
I think everyone who makes Carb parts are improving the alloys for ethanol resistance out of necessity.  But I don't think that was Keysters problem.  If I remember correctly, Keyster had a fitment problem with some components.  Like the angle of the tip of the float valve was not right and the taper of the needles was off.  Things like that.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: November 02, 2011, 11:36:03 AM »
The needle taper was the problem I had with them. Compared Keyster's to OEM using a drill gauge to check how the tapers differed, and they did, by quite a bit. I ended up just using the old [OEM] needles.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: November 02, 2011, 02:27:46 PM »
you would think if they made both the float needle and valve they would make it the same angle.
I try and get HONDA oem when it comes to carbs. They are usually not much more money and the lack of headaches are worth more than the that.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline fmctm1sw
« Reply #4 on: November 02, 2011, 05:10:15 PM »
I was aware of the needle taper issues, I just wanted to throw this out there a little sarcastically.  I've started keeping my old jets and stuff and just replacing o rings.  I think that was talked about in another thread...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
