Author Topic: square peg in a round hole..I need help!  (Read 2363 times)
Offline toytuff
  • "watching the pinheads"
« on: November 03, 2011, 06:51:12 PM »
Can anyone tell me the secret of installing float bowl gaskets that are way to big?  ???
The gasket kit is the right part number. I had these on then had to remove the bowls. Now they seem way to large. The gaskets are not flattened but now they are way off.  ???
I know, it does sound crazy. What am I missing? Bourbon perhaps?
tt
Re: square peg in a round hole..I need help!
« Reply #1 on: November 03, 2011, 08:31:24 PM »
Looks like the wrong part? Did it come as part of a kit?
Offline 78 k550
« Reply #2 on: November 03, 2011, 08:40:47 PM »
Dab a little vaseline/petrolatum  in each corner.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline grcamna2
« Reply #3 on: November 03, 2011, 08:45:25 PM »
Johnnie,
               Glue 'em in w/ a little gasket cement...mine were the same;I just ran the gasket all the way to the extreme outside of the groove and when I installed them they sealed excellent.The old ones are shrunk & in the shape of the bowl groove from sitting in there so long;the new ones are always round.
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: November 04, 2011, 04:41:45 AM »
Using gasket sealer is a gamble.  Anything silicone based will expand a lot when in contact with gasoline, then little bits of it will fall off inside the bowl and can easily clog up the jets.  Use something like grease or petroleum jelly like Paul suggested and you won't have to worry about that.
Offline Doum
« Reply #5 on: November 04, 2011, 05:08:37 AM »
A small shot of krazy glue in each corner
Offline trueblue
« Reply #6 on: November 04, 2011, 05:26:02 AM »
Permatex Aviation gasket sealer should be fine to use and will hold the gaskets in place quite well
1979 CB650Z
Offline KB02
« Reply #7 on: November 04, 2011, 05:43:08 AM »
I use something like this:
It helps to hold it in place. Spray each side, give it a minute to set up and then it should be good and tacky enough to hold to the grove. Available in just about any auto parts store.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline grcamna2
« Reply #8 on: November 04, 2011, 05:49:38 AM »
        I use very small dabs of Permatex "Form-a gasket" in a tube & there are 2 types;the non hardening that stays pliable & the hardening type...you choose.
Offline heffay
« Reply #9 on: November 04, 2011, 12:43:56 PM »
Don't use sealer, if Mr. Honda didn't use it you don't need to either.
Here's what I've done with repeated success.
use little pieces of tape, I prefer blue painters tape as it doesn't stick too much, tape over about 1/2 the gasket, just enough to hold it in the channel, do this all around the bowl.  put the bottom part of the bowl on w/out screws and gently pull the tape out.  you'll have to keep the tension on the bowl surfaces just right to allow for pulling out the tape, but it works like a charm!  then put your bowl screws in and voila.
Offline toytuff
« Reply #10 on: November 04, 2011, 01:51:22 PM »
Thanks to all for the tips and not what/what to use. Great ideas abound here.  8)
I need to take a break for the weekend. I have removed/installed the bowls 5 or 6 times while the carburetor is on the bike, mostly from not thinking things through. My bad. No one else. Triple work also.  ::)
Here is what I found.
Left side primary jet plugged with old fuel. Fixed.
Replaced all seals/o rings. No directions. You guess.
Cleaned all jets.
Both left and right idle jets plugged solid. Fixed. Idles well now.
Now, the right float or float valve does not close dripping out bottom of float (drain tube). To much fuel in bowl. Funny thing is I didn't touch them. Float valve appears to work as intended.
Thinking now the float needs adjusted but I wouldn't know why. Like I said. Never touched them.  I have a spare carburetor for parts so I'll adjust the spare float. Need to keep original float at it's setting for reference.
More than likely I need to order new float needles but hoping not.
The "G" was moving right along. PIA now.  :P
tt
Offline Steve_K
« Reply #11 on: November 04, 2011, 03:24:02 PM »
I have used grease to hold the oring in place.  Works for me, but the suggestions already listed looks reasonable, too.
Steve
Steve_K
Offline trueblue
« Reply #12 on: November 04, 2011, 03:56:13 PM »
Cleaned all jets.
tt
With that leaky carb, just give it a tap on the bottom of the float bowl with the handle of a screw driver, the float valve may just need settling back into place.
1979 CB650Z
Offline toytuff
« Reply #13 on: November 04, 2011, 04:09:31 PM »
Cleaned all jets.
tt
Been there.  ;)
I'll try adjusting float next week. If problem persists than new gasket kit, float needles and into the shop they go.
If any member here does carb work chime in. I love the shop here but three (3) months for the last set is a long time to wait.  ::)
tt
Offline trueblue
« Reply #14 on: November 04, 2011, 04:18:10 PM »
Hondaman does them here is a link to his site
http://sohc4shop.com/catalog/product_info.php?cPath=24&products_id=47
1979 CB650Z
« Reply #15 on: November 04, 2011, 04:42:59 PM »
Digger also does carb rebuilding.
Offline toytuff
« Reply #16 on: November 07, 2011, 06:28:10 PM »
Problem solved. No more leaking.  ;)
tt
Offline heffay
« Reply #17 on: November 07, 2011, 06:36:27 PM »
tell us what worked for you!  ::)
Offline toytuff
« Reply #18 on: November 08, 2011, 06:15:10 AM »
Well..ok..ok.  :-[
I changed out the float bowl with my spare. It was much cleaner and the gasket was in much better condition.
After swapping out floats, float needle and new O rings the light came on. The brass drain tube that runs inside the float bowl had a hair line crack from top to bottom inside.  Needed a LED flashlight to see it.  ::)
Pretty rare I would think but none the less the root of the problem. Won't forget to look at that next time.
All good now. Thanks everyone for the tips and/or tricks.
tt
« Last Edit: November 08, 2011, 07:44:06 AM by toytuff »
Offline heffay
« Reply #19 on: November 08, 2011, 06:50:56 AM »
Good eye, you'd have been fighting that for a long time had you not seen it!  Well done.
Offline toytuff
« Reply #20 on: November 08, 2011, 07:45:26 AM »
Just had to think it out. Couple of days but I had a Senior moment is all. Get them all the time.  ::)
tt
