Author Topic: CR750 replica for the street  (Read 80779 times)
Re: CR750 replica for the street
« Reply #275 on: December 02, 2018, 05:15:13 AM »
Vincent its very rare for riders to actually describe how it feels to ride a bike like the CR750 so I for one appreciate the insight. And totally agree with your and Jay Lenos philosophy about bikes. Cant wait to hear and see more.
cheers
Andy
« Reply #276 on: December 02, 2018, 02:51:02 PM »
Vincent,
I'm so happy to hear that the bike has been getting so well received!  I'm looking forward to seeing on Jay Leno's Garage.  That's amazing!!
Well done, my friend!
Don
Offline Vincent
« Reply #277 on: December 02, 2018, 03:18:06 PM »
Hi Andy,
OK, I'll tell you about riding the CR. I still have some things to work out, and the bike is still in its break-in phase, but but here are a couple of things. I have to give it a lot of gas to start it when it's cold, and then it's a little hesitant for about a minute. The CR carbs don't have ports to attach vacuum gauges, so at this point I'm just going on the bench sync, but if I can figure out an unobtrusive way to mount vacuum ports, I'll do it. I thought my legs would be be really cramped by the high-up and far-back footpeg position, but it's actually not bad. On my first couple of rides, when I'd pull away from a stop my legs would be waving around while I located where to put my feet. My other bikes have pegs in the "normal" place, but once I rode this one a few times, muscle memory kicked in, and now it's not a problem. But (as PeeWee Herman said, there's always a big but) the clip ons are a whole other issue. They're forward and down, so the weight of your upper body is supported by your hands. If you're going about 70mph on level ground, it's not bad, because there's enough air under your chest to give some support, but at slower speeds it can make you sore. The worst is coming down from the mountains, braking in downhill turns. Ouch. Also, try sitting in your chair and leaning forward as if you're holding those bars. You're probably looking at a spot on the floor just a few feet ahead of where your front wheel would be. But lift your head as though you're looking down the road, and imagine holding your head like that for a few hours. It's funny that clipons and clubman bars are popular these days. The look apparently attracts people who have never ridden, but the reality of the riding position might be a rude awakening to them, as it requires a level of dedication. I wonder how many butchered, twice-ridden Hondas are gathering dust in hipster garages.
Alright, that's the bad news. On the other hand: every time I get on the bike, it feels like an adventure. First, the sound is fabulous. Oops, wait, there's a first before that. When I open the garage door and see the bike sitting there, I can't believe that I have it. This is what I'm going to ride! I've wanted this since about 1992. That's when I started collecting photos and descriptions. And dreaming.  A couple of years ago I bought a Tamiya 1/6 scale model of the Dick Mann Daytona winner, figuring that when I had completed the big one, I'd build the miniature to match. So that's an upcoming project. The bike is not like anything I've ever owned. Every bike is different from every other bike, but this one is so different from my '70 Bonneville and '77 GL100 that I almost feel like a different person when I'm riding it. And leaning forward makes me feel more active, almost as though I'm flying through the scenery. It's unique, demanding, and totally engaging, and every time I look at it, I'm in awe of the fabrication skills of Takashi Iwamoto and Mitsuhiro "Kiyo" Kiyonaga. The beautiful sweep of the pipes, the instrument panel, fairing mounts, fender mounts, seat and tank mounts. Those guys are artists as well as gearheads. I like to figure out how to do everything myself, and when I started this I thought I'd learn how to weld and make all the mounts on my own. Ha! It would take me a million years to do what they did.
The sound. Whether you're going 20mph or 80mph, it sounds like you're at the races. When we stop at a light, if I want to speak to my riding buddy Will, I have to kill the engine. Winding through the canyons, going up and down through the gears, hearing the sound bouncing back off the canyon walls, everything seems to fall away except awareness of the bike. When I see that I'm going to cross paths with a patrol car, I go up a gear, and so far I haven't heard a noise complaint. Or maybe I just haven't heard anything because the bike is making me deaf. Hmmm.
I have 18 inch rims front and back, and that should make the steering a bit quicker, but I'd have to ride it back to back with a stock one to really feel it. Having two discs up front definitely is better. At some point I'll make it to a recycling place and put the bike on a scale, but it's definitely lighter than stock. I'm going to make aluminum spacers to hold the mirrors out farther from the fairing, because I have to move my arm and my head to see behind me. The bars are adjustable aluminum Tomaselli bars,and I chose them because they're a little longer than other bars I looked at. That gave room for the switch gear, and also provides a little more leverage. I had the crank balanced to 12,000rpm and micropolished by APE Raceparts, and the engine feels smooth and free-revving. The Barnett clutch doesn't do that rattle thing that the stock clutch does. When I took the transmission apart, I used a micrometer on all the parts, and there was very little wear on anything, so I just replaced the bearings, bushings, and seals and put it back together. I'm very happy with the way it shifts.
I rebuilt a set of NOS aluminum-body Koni shocks with internal parts from Ikon and springs from Revival in Austin, but they're too stiff. The shocks are adjustable for preload and damping, but for damping you have to take the springs off. And since things are so tight on the bike, everything is an interference fit. I have to drop the pipes to remove the bottom shock mount bolts, and I just haven't gotten to it. I adjusted the preload up a notch because the rear tire occasionally hits the bottom edge of the license plate, and I'll have to trim the top of the plate and move it up a little so I can loosen the preload. Still more things to attend to.
But when I ride it anywhere, it draws people in. There are thumbs up from people on bikes and in cars. And picture takers: girls stand next to it while their guys snap photos! Crazy!
Last time I mentioned going to the Venice Vintage Motorcycle Club Rally, and I forgot to mention that I ran into two forum members Don (SOHC Cafe Racer Fan) and Duncan (Dunc). Good to see them in person.
Smokey and The Bandit
That's it for now. Thanks for looking
Vincent
Offline Vincent
« Reply #278 on: December 18, 2018, 11:14:26 PM »
Hi!
Well, it's done. We filmed the episode, and I was able to take a bunch of pictures before the professionals took over. Here are just a few. The lighting was just perfect, and the pictures look like magazine shots. The bike was posed under a giant softbox hung from the ceiling, and you can see it in the first picture. It provides a lot of soft light over a wide area, and the only shadow is directly underneath the object being lit. Because the floor is painted a light color, it reflects light back up to illuminate the undersides of curved surfaces. You can see that the fairing is lit pretty much uniformly from top to bottom. The last picture shows the boom-mounted video camera. I took a short video of Jay riding past the camera and uploaded it to imgur, but it doesn't have any sound. If someone can tell me how to post it here (with sound), I'd like to do it. Thanks in advance for any help.
They filmed the bike at rest in the Bugatti Room for about an hour, then they filmed Jay and I talking about the bike, then we ate lunch, then Jay rode the bike and we rode next to him in a camera car, then they filmed him speeding by from the side of the road, then they filmed us again talking about his ride. The place was absolutely incredible. Two vast buildings full of vehicles. High ceilings, exposed beams, and the walls are covered with large hand-painted - on canvas! - reproductions of magazine covers, print ads, movie posters, and advertising signs. Hot rods, dragsters, customs, classics, sports. American, European, Japanese. Steam, electric, jet,and gasoline. Cars, motorcycles, tractors, firetrucks, car transporters, V12 airplane engines on stands, cutaway display chassis and engines. Vehicles from 1914 and vehicles from 2018. Not just a Duesenberg or two, but a dozen. Not just a Vincent or two, but 10. 24 Brough Superiors. Eight Bugattis. Ferrari, Delahaye, Jaguar. Lamborghini Miura. A Mercer Racebout, all flat fenders, wood floor, monocle windshield, and brass acetylene headlights. Blower Bentley. Custom-bodied 1934 Rolls Royce with a Merlin V-12 airplane engine. Jet car. Jet motorcycle. Steam motorcycle. Chrysler Turbine Car. Tatra. Yenko Stinger Corvair over here, a Maserati 3500 over there. A Fiat Topolino. Munch Mammoth. MV Agusta. Rare bikes. Mass-produced bikes. Pristine bikes, track-worn bikes, bikes waiting restoration. The Honda CBX that he bought new when it was first released. A supercharged Suzuki. Gran Prix bikes, street bikes, custom bikes. Rows and rows of them. Everything has current registration and battery chargers hooked to their batteries. They're ready to roll. Half-assembled cars on rolling tables, with shelves of newly painted parts standing by. A 1914 electric car, tall and skinny, with a mohair interior. A perfect white Austin Healey body with no hood, interior, or running gear. Showrooms, machine shop, paint and body shop, upholstery shop, TV production studio, screening room, living room, kitchen. The have a waterjet cutter, 3d printer, lathes, milling machines, French wheels - every kind of tool you can imagine. They're able to laser scan a piece, 3D print a copy in resin, use the resin piece to make a mold, cast a new piece in aluminum, paint it, machine it, and install it on a car. They can fabricate complete car bodies. A crew keeps the place going. Mechanics, painters, machinists, and a TV crew. Younger people, older people, all professionals who seem to really love what they're doing. Jay was just how you hope he would be: very friendly and casual, and when you speak with him, it's easy to forgot that there's a bank of cameras watching everything. He's amazingly knowledgeable about all his vehicles, knows all of their quirks, and seems to like them all for what they are. It was an excellent experience, and it'll be on Jay's YouTube channel in either January or February. I'll let you know.
Thanks for looking
Vincent
« Reply #279 on: December 19, 2018, 10:02:45 AM »
Makes a BOTY award pale in comparison... sounds like an absolute fantasy for a gearhead to visit behind the scenes. Well deserved, and well earned, Vincent. Still a fabulous bike! Jay is lucky to have ridden it  ;)
Agreed!  This is, BY FAR, the BEST recognition I can think of.  And it is extremely well-deserved.  I cannot think of much better kudos for all of the detail-oriented hours you spent than to have it recognized on a national/global scale and to share some time with such a recognized aficionado who wanted to know he appreciated it, as well.
Offline Rocketman
« Reply #280 on: December 19, 2018, 11:27:35 AM »
My hat is off to you!  Thanks for taking us along for the ride.  The DVR is on standby!
Offline Vincent
« Reply #281 on: December 19, 2018, 10:16:45 PM »
Thanks so much for all the positive words. After all the sweating, fretting, wrenching, cursing, making parts that didn't work and then throwing them away and starting over, I still can't believe it's done. And then to have people think it's cool! I'm really still on a high. But somebody please tell me how to upload a short video of the bike running! Either through imgur or some other way. I think you'll like it.
Vincent
Offline CBJoe
« Reply #282 on: December 20, 2018, 04:07:10 PM »
I find one of the best ways is to have a you/tube account where you can post it to your "channel".... you can do it in a way that it isn't public and only those with the link can view it.
But if you post the link to your thread it will show up as embedded.
If you don't have a youtube account and don't mind me posting it for you I can.
Regards, Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline CBJoe
« Reply #283 on: December 21, 2018, 09:15:18 AM »
Here ya go Vincent
'65 CB77
'66 CM91 (C90'ish)
Offline Vincent
« Reply #284 on: December 21, 2018, 09:53:07 AM »
Thanks, Joe! The only thing I have to add is TURN IT UP!
Vincent
« Reply #285 on: December 21, 2018, 10:55:32 AM »
Those pipes sound terrific!!
« Reply #286 on: December 21, 2018, 03:59:48 PM »
Markb’s K0 #97, your CR replica, it doesn’t get better.
What a great forum, what a great tribute.
Offline Vincent
« Reply #287 on: December 22, 2018, 11:24:09 PM »
Well. Just realized I haven't said what the video is. Or rather, who the video is. It's not me, it's Jay. I rode the bike up there and rode it back home, but the only person who was filmed riding it was Jay. They wired up his helmet, and he did a running commentary while he was riding. I haven't heard it, so we'll hear it at the same time when the episode hits Youtube. Here's a picture I took from the camera car as Jay was about to pass us. At this point we were on the way to where they filmed him doing the the drive-by.
Vincent
Offline Godffery
  • Godffery's Garage
« Reply #288 on: December 23, 2018, 10:14:15 PM »
 In lieu of going threw all 13 pages; I'm just going to ask...
Can I get the details on that exhaust system?
« Reply #289 on: December 23, 2018, 11:34:43 PM »
Why wait?
Answer on first page
Four-into-four exhaust system from our own Lord Moonpie
Hint: Search each page with Ctrl+f, write exhaust in the search box
http://www.moonpie.co.uk/html/cr750_resource_page.html
« Last Edit: December 24, 2018, 02:09:30 AM by PeWe »
Offline Godffery
  • Godffery's Garage
« Reply #290 on: December 24, 2018, 08:37:24 AM »
Why wait?
Groovy, Thank you very much!
« Reply #291 on: December 24, 2018, 09:03:27 AM »
Why wait?
Those Lord Moonpie pipes come unassembled in "several" pieces, requiring welding and no instructions.  Not too much of a challenge for Jeff/Godffery but just letting the rest of the class know.
Offline Vincent
« Reply #292 on: December 24, 2018, 01:22:00 PM »
Wow, you guys are on top of things! The exhaust system consisted of four header pipes and four megaphones, arrived in a big, sturdy plastic bin, and were perhaps the best-packaged of all the things I bought for the bike. And they sound fabulous!
Vincent
Offline Godffery
  • Godffery's Garage
« Reply #293 on: December 24, 2018, 06:31:09 PM »
Why wait?
I did notice that, and it is a challenge I would willing except for such Groovy exhaust.   ;)
« Reply #294 on: December 26, 2018, 12:35:24 PM »
Hey Vincent....your bike is featured in my 2019 BOTM calendar....PM sent.
« Reply #295 on: December 26, 2018, 05:52:55 PM »
Why wait?
Kevin in South Africa (TTR400) was making replicas of these and selling them. Excellent quality and no reassembly required.
Offline Vincent
« Reply #296 on: February 18, 2019, 01:05:13 PM »
Hey!
The episode went up on YouTube last night! Just Google Jay Leno's Garage, and it's the newest video.
Vincent
Offline CR21
  • Next project... A CR750 replica...?
« Reply #297 on: February 18, 2019, 01:52:54 PM »
Hey!
Vincent
Nice! What a lovely day for the filming, and the bike is looking fantastic - good work  :)
Cheers
CR21
« Reply #298 on: February 18, 2019, 02:01:52 PM »
Vincent in the latest issue of Cafe Racer.
« Reply #299 on: February 18, 2019, 02:31:19 PM »
I caught Jay Leno’s show last night. Very cool. What a beautiful bike.
