Author Topic: Fork oil drain plug helicoil repair?  (Read 1737 times)
Offline Brantley
  • Drano
« on: November 06, 2011, 04:15:35 PM »
I'm doing some front end work on a friend's 750F1, part of which is replacing the fork seals. Well, the PO done wrapped the fork oil drain plug with plumbers tape 'cause the threads in the slider are stripped (and I just CAN NOT wrap my brain around how one could cross thread something so accessible). Am I correct in assuming I can repair this with a helicoil as the copper crush washer does the sealing? Anyone tried this? Results? Of course it's an F and my spare sliders are K...
« Last Edit: November 07, 2011, 11:53:02 AM by Brantley »
Online CycleRanger
  • No comment about being an
Re: For oil drain plug helicoil repair?
« Reply #1 on: November 06, 2011, 04:22:51 PM »
I just had a heli-coil installed in the drain hole of one the lowers from my XL250s.
The threads were stripped out of the hole.
I haven't re-assembled the fork yet but I don't expect any problems with it.
You might be able to get away with just carefully chasing the threads with a tap.
« Reply #2 on: November 06, 2011, 04:43:39 PM »
I wouldn't worry as the torque from the bolt pulls the coil tight. They work for sparkplugs....I wouldn't worry. But....just get a used pan....they are cheap enough on ebay.
Offline 2wheels
« Reply #3 on: November 06, 2011, 07:54:53 PM »
Why not just drill and tap a size bigger?
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
« Reply #4 on: November 06, 2011, 08:09:54 PM »
Add fork to your title because some are thinking your talking about the engine oil pan.Looks like you got the FOR but forgot the ending K ;)
« Last Edit: November 06, 2011, 08:15:09 PM by ekpent »
Offline caluser2000
« Reply #5 on: November 06, 2011, 09:07:58 PM »
Sort answer is yes you can helicoil them without a problem.
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline Brantley
  • Drano
Re: Fork oil drain plug helicoil repair?
« Reply #6 on: November 07, 2011, 12:05:03 PM »
Oops. I usually don't post so hastily...
Not my bike. I want to leave the guess work out of it in case that bolt goes missing in the future. And that really seems like more work having to find the appropriate length 7mm bolt (or cutting one to size) AND a 7mm copper crush washer.
Good point, Mike. Hadn't looked at it like that.
Thanks, all. I'm goin' for it.
