Wsup fellas. As per subject, I was replacing my stock mini ape hangers on my '77 CB750 K7 last night and ran in to some minor issues. I'll break it down for ya...
1.) I don't see a protruding piece of plastic or metal from the throttle housing to keep it in place; does that mean there's no need for me to drill a hole in the bar to keep it from moving?
2.) My new handlebars aren't knurled like the stock ones, do I need to apply some type of material between bar and clamps so that the bar will stay in place? If so, what do you use?
3.) It appears that grease was applied between the throttle sleeve and handlebar, do I use just generic grease or is there any specific ones to use? Can I use motorcycle chain lube?
![Cheesy :D](http://forums.sohc4.net/Smileys/default/cheesy.gif)
That's about it... for now. I've only replaced spark plugs and oil/filter on bikes in the past, hence the inquiries. TIA!
