Author Topic: True/False triple tree question.  (Read 1334 times)
Offline Blitzburgh207
« on: November 10, 2011, 03:48:27 PM »
T/F - A k4 top triple will fit on a k8 lower and stem.  ...I searched but people have claimed both sides.
I'm asking because I want to run clip-ons and I'm going to shave the handlebar mounts.  I would just shave the upper from the k8 but i'm still riding fairly regularly and I'm trying to get a head start on winter work.  :)
Thanks!
1978 CB750 K8
Re: True/False triple tree question.
« Reply #1 on: November 10, 2011, 07:10:12 PM »
K4 will not fit on K 7 or K8 lower..
 Skaving the upper from a K8 will have huge holes
« Reply #2 on: November 11, 2011, 10:21:08 AM »
Ok now another two questions:
1. I don't see why it would be - but since the geometry is apparently different, would it be unsafe in any way to use the k4 triples on the k8 frame? Can I still use my k8 wheel?
2.  I could just fill those spaces w/ weld on the k8 top triple before cutting and it should have a decent finish ya? - I would have to fill the [smaller] holes on the k4 top triple too...
Ok I guess that's three questions  ::)
Thanks again!
1978 CB750 K8
« Reply #3 on: November 12, 2011, 12:22:40 PM »
 You can swap triples as a set.
 K8 will leave a grape size holes, the earlier one is pea size.. lotta heat to put into the tree.
« Reply #4 on: November 13, 2011, 05:52:06 AM »
Good point - I hadn't thought of that. Thanks man!  I'll probably just use the k4 set then.
1978 CB750 K8
