Author Topic: Is this intake tube damaged? Take a look please.  (Read 1389 times)
Offline eworth
« on: November 23, 2011, 04:27:13 PM »
Hey,
Just got my headwork done along with matching to the intake tubes and plenty other work besides on this head.
Man, I don't recall the intake tube on the far right being out-of-round?    I don't see any apparent damage other than it not being round in shape.   Is that the way it should be?  The other 3 look good.
If its damaged, any one have the right intake tube that'll fit the 77 CB550F.   The stamp on the part is B-8.
Sure hope that's the way it way supposed to be or I'll be contacting the machinist.
Thanks for looking..   Mark
Re: Is this intake tube damaged? Take a look please.
« Reply #1 on: November 23, 2011, 04:33:34 PM »
I wonder if it was put in a vise when the work was done.
Offline eworth
« Reply #2 on: November 23, 2011, 04:35:39 PM »
That would make sense.  It was packaged real well so I don't think it was in shipping.  So, we agree?  Shouldn't be like that?
Offline FuZZie
« Reply #3 on: November 23, 2011, 04:57:33 PM »
looks like vice to me too, check for a corresponding mark of some kind where the other side would have been.
« Reply #4 on: November 23, 2011, 05:01:14 PM »
They are supposed to be round, and were from the factory.  I think they would be difficult to seal in an out-of-round condition.
Offline eworth
« Reply #5 on: November 23, 2011, 05:03:59 PM »
Ya, I agree.   Went and looked on the internet and confirmed after posting.
Wonder if there is an easy way to re-shape it to round again.
If  not, will all CB550s and CB500s intake tubes be the same???   Anyone know?
Thanks,
Mark
« Reply #6 on: November 23, 2011, 05:34:50 PM »
You will want to avoid the intake runners destined for the PD carbs of the 77-78 Cb550K (no vacuum balancing ports).  The rest of the Cb550s will work with the 069a carbs of the Cb550F.
Offline eworth
« Reply #7 on: November 23, 2011, 05:36:32 PM »
Perfect TT.  Now I know what I'm looking for.   One more question TT.   Would any CB500 or CB550 intake tube work as long as they have the Vacuum port you mentioned?
« Last Edit: November 23, 2011, 05:43:09 PM by eworth »
« Reply #8 on: November 23, 2011, 10:37:03 PM »
AFAIK, the Cb500 intake manifolds are the same as most of the Cb550s.  I haven't personally swapped them, though.
« Reply #9 on: November 23, 2011, 10:45:04 PM »
was that returned to you like that?its a major wrong thing,no way that was from the factory,take it back to your machinist and politley ask for a replacement,,there is no way that was ever used as it is,if it stuck out like a sore thumb now it would have when you took it apart,it wouldnt take much of a crimp to cause a crack though on that alloy,i think its been in the vise or similar too hard?ive had these things in the vice with rag wrapped around them and practised a little finnesse during cleaning etc,,i call foul!you certain it was fine before?
« Last Edit: November 23, 2011, 10:50:18 PM by dave500 »
Offline eworth
« Reply #10 on: November 24, 2011, 04:40:49 AM »
Yes, I'm sure it was fine before.  Not only that, I would think the machinist would have said something if it arrived in that condition.  I have sent an email to the machinist.   They are open the day after thanksgiving so I'll be giving them a call.  Sent them photos also.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #11 on: November 24, 2011, 05:52:42 AM »
I have a set of intakes from a 77 550F. If you need them, let me know.
........Paul
Offline eworth
« Reply #12 on: November 24, 2011, 06:50:52 AM »
PM sent Paul
Offline verslagen1
« Reply #13 on: November 27, 2011, 05:30:24 PM »
put a couple heat lamps on it for a week.
it might return to the original condition.
I fell on my ski pole years ago and bent it pretty good.
I had a Vdub camper and stuck it up in the roof and forgot it.
When I found them again, it was straight again.
Hey, can't hurt.
'88 Savage Daily rider
'72 CB500 Garage find
Offline eworth
« Reply #14 on: November 27, 2011, 05:34:03 PM »
I ended up heating it up considerably and pounded a tapered wood table leg into the opening.   Straightening it out pretty well.  Did buy a back up from ebay though that hasn't arrived yet.
« Reply #15 on: November 27, 2011, 07:26:11 PM »
Yes. I have installed vacuum ports in those that do not have them.
Offline eworth
« Reply #16 on: November 27, 2011, 07:32:55 PM »
Thanks for the reply Mike.  I was able to find an identical set to the ones I have on ebay for cheap.
