Author Topic: Suggestions on these 550 carbs  (Read 1190 times)
Offline Mcwilliams570
« on: November 08, 2011, 02:44:19 PM »
Hello all I cleaned these carbs about 3 months ago with simple green diluted with water then rinsed them after they were done soaking. I put them up on a shelf and the other day I pulled them down to fit onto the engine for the tank I was putting on and noticed this white deposite all over them.
Lastnight the wife was out so I put them in the dishwasher and after the white deposits are still there. I think  this is a chemical reaction with the simple green but thought I rinsed them really good.
Any suggestions on what I can do to help get them clean again would be very much appreciated. I know I can scrub most of it off but was thinking of soaking them again in something to get them clean again.
Thanks Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Randy
  • Nothing like a banging four under my legs..
    • Mission Detail
Re: Suggestions on these 550 carbs
« Reply #1 on: November 08, 2011, 02:52:31 PM »
I had the same problem when I soaked mine the frist tiem..What I did was take them all apart..I know it sounds like a big job but it isn't really... I found a break down page that was a step by step.. And it can be fun .. I cleaned my carbs with bathroom bowl cleaner and then washed and dryed with a heat gun..So that wouldn't happen.. then polished the carb bodies with a dremel and put them back together...
1973 CB500k, 1972 CB750 (New Arrival), 1978 Vespa P200 (New Arrival)
Offline Randy
    • Mission Detail
« Reply #2 on: November 08, 2011, 02:53:59 PM »
all together..
Offline Randy
    • Mission Detail
« Reply #3 on: November 08, 2011, 03:01:53 PM »
http://www.spookytoms.com/SpookyTom-500-72-RB8A.html
I wouldn't go as far as taking the choke apart, but if you really want to clean..
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #4 on: November 08, 2011, 04:03:36 PM »
You could maybe try white vinegar & a toothbrush. It wasn't white oxidation, but it worked a treat on my float bowls back here:
http://forums.sohc4.net/index.php?topic=61168.msg717941#msg717941
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #5 on: November 08, 2011, 04:37:18 PM »
How long did you guys soak those carbs?  I used Simple Green and the bodies came out  fine, although there has been mention in other threads of Simple Green darkening aluminum.
« Reply #6 on: November 08, 2011, 05:08:52 PM »
Thanks for the replies guys. I only did the soak for a hour or so with the simple green and then rinsed real good. I will wait for a few more responses and will do some more research before I do anything else to them. Let ya all know what happens.
Matt
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline TicoCafe
« Reply #7 on: November 09, 2011, 06:59:24 AM »
I soaked mine in PineSol for 24hrs (50/50 water/pinsol)and they came out flawless... polished the tops with a dremel.
Pura Vida!
Offline Lostboy Steve
« Reply #8 on: November 09, 2011, 07:16:57 AM »
I used lacquer thinner. Soaked them for 24 hours. Then I boiled several parts in vinegar / water mix.  Last I replaced all rubbers and gaskets cleaned the jets with a Torch tip cleaner. Lastly I squirted a little 3n1 oil on the slides / linkages and gave each one a few pumps. They look brand new and work well.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline luap
  • LAWL
« Reply #9 on: November 09, 2011, 12:15:29 PM »
have you tried brillo pad an some elbow grease to get the white build up off, if you take them all apart try 50/50 simple green with some heat under the bowl, camping stove or turkey burner works well
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline mrtanner101
« Reply #10 on: November 09, 2011, 03:33:01 PM »
littlegreena100 --- Mind if I ask you what those carbs are off of?  And maybe the code on them?  I'm about to buy a set that looks just like those...
1977 Honda CB550F - The long term project
1972 Chevy C50 - The Workhorse
2002 VW Beetle - Daily driver
« Reply #11 on: November 09, 2011, 10:26:11 PM »
They are off a 1974 cb550 code 22A.
Matt
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline Randy
    • Mission Detail
« Reply #12 on: November 11, 2011, 06:51:12 PM »
Nope my 73 CB500K2...
